self clearing codes? '14 6.7L
Old May 4, 2021 | 12:47 PM
Jimmy Dean82's Avatar
Jimmy Dean82
check engine light came on first start of the day, was on for a shortish drive, did not come on when restarted 20 minutes later. still going to have codes run but do not expect anything to come of that. Used to codes staying longer, or until cleared, even if the issue goes away or doesn't present again.
are there any codes that only show up when it happens? going to keep a close eye on it on cold starts, guess if this repeats I'll move the CTS Edge I have on my 6.0 over to this to record codes at the start.
Old May 4, 2021 | 01:55 PM
dirthawg's Avatar
dirthawg
Most likely whatever was out of spec during the first drive to set the check engine light returned to normal before or at the time of the restart. There should be a code stored in history even if the check engine light is off. Hopefully it's just a fluke thing and all will be good or you could have a potential issue starting and this is the first warning.
Old May 5, 2021 | 07:30 AM
The Bone's Avatar
The Bone
I don't worry if the light goes out. You only have to worry if it just stays on. Its not uncommon for this to happen. Truck fixed itself. Great day
Old May 5, 2021 | 04:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The code should have stored in memory even if the problem corrected itself. You might have a problem with keep alive memory power to the PCM.
bronco6767
May 14, 2016 02:49 PM
iateatoad
13
Dec 8, 2012 10:35 PM
ItsAFord55
Mar 13, 2012 06:51 PM
smolicht
Nov 16, 2006 09:53 AM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
