1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Turbo limiter?
Old 05-03-2021, 08:41 AM
Daniel Hancock's Avatar
Daniel Hancock
Daniel Hancock is offline
Turbo limiter?
2009 F350 6.4 Crew Cab LB Dually
DPF delete, CAI, +50 hp tune
When towing my 15k 5th wheel through Colorado mountains, I can get to 30psi on the turbo. I make sure I don’t go over that, but would like a way to electronically limit it and ensure I don’t.
Thoughts?
Old 05-03-2021, 09:19 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
30psi of boost is not an issue. Stock tuning can reach that. You need to watch EGT’s when towing.
The following users liked this post:
Old 05-03-2021, 09:37 AM
Daniel Hancock
EGT?
Dumb question, what’s ETG? Do I have to just manually do this or can I get a limiter?
Old 05-03-2021, 10:28 AM
CCROCHET50FORD's Avatar
CCROCHET50FORD
CCROCHET50FORD is offline
Egt’s are your Exhaust Gas Temps. That temp you need to monitor when towing
Old 05-03-2021, 10:59 AM
99powerstrokedF250's Avatar
99powerstrokedF250
99powerstrokedF250 is offline
That and your oil temp. Oil temp should never be more than 20-30° higher than coolant temp.
Old 05-03-2021, 11:32 AM
Daniel Hancock
EGT temp
How do I monitor the EGT temps?
Old 05-04-2021, 05:30 AM
senix's Avatar
senix
senix is online now
Received 1,468 Likes on 1,048 Posts
If you are running a tuner, then you need a monitor.. Many places make them.
Banks makes an idash that will be a plug and play in the OBD port. Then you can monitor your coolant, oil and EGT temps. My 6.4 would pull 40 psi all day long. 41 PSI is the cut off using factory programming.
My coolant temps would run 196 or so unloaded and around 220 heavy towing cross country. Clutch fan kicks on high at about that temp.
Oil temps hovered around the same.
Trans temps, I tried to always stay 210-220, but 230 for brief periods was ok.
EGT or exhaust gas temp. Since the motor was made for emissions, from the factory, a 1300 F EGT was a normal temp. Don't exceed that.
Best advice I had always followed was when towing less than 10K I would run a mild tune. Anything over that amount was in stock power levels. Never lifted the heads and then had issues.
I would tow cross country in mine.
Old 05-04-2021, 09:46 AM
Daniel Hancock
Thanks!
Fantastic information, thank you!!! I will look for that Banks.
Old 05-04-2021, 09:56 AM
senix's Avatar
senix
senix is online now
Mine retained all the emissions components. So my tuner was the Banks 6 Gun.
I used that since it retained all factory safe features and was emissions compliant.
My over all fuel mileage was 11.5 mpgs over the life of the truck.
Colorado350
30
12-13-2020 12:29 PM
bodabdan
6.7L Power Stroke Diesel
07-15-2013 10:36 PM
Skyquest
06-11-2012 07:51 AM
i eat hybrids
Ford Truck Parts for Sale
12-07-2011 10:10 AM
eric777
16
07-18-2006 11:32 PM
Quick Reply: Turbo limiter?
