PROBLEM: Both High and lo Beam on
Old Apr 30, 2021 | 10:56 AM
robdog6942's Avatar
robdog6942
Hey Guys & Gals,
I am having a problem with my F250 headlights both high and lo beam being on at the same time regardless of high beam switch position. No change whatsoever when trying to switch. Any ideas?
Old Apr 30, 2021 | 11:14 AM
Pugga's Avatar
Pugga
Any modifications to the truck's lighting? Wondering if you have an aftermarket drop in LED kit, aftermarket headlights or something else tapped into the lighting wires. If so, start there which might mean going back to stock lights. If not, I'd guess the switch in the steering column is malfunctioning. Short term, you should be able to pull the high beam fuse so you're only left with low beams.
Old Apr 30, 2021 | 11:25 AM
mhoefer's Avatar
mhoefer
Need to tell us year, options, trim level and what other things have been done, could be the high beam stock, could be the auto high beams, could be the sensors for high beam behind the windshield top centre, could be a damaged wire.....
If you haven't touched anything, clearly dealer first, especially if you have warrenty.
Old Apr 30, 2021 | 11:44 AM
ford390gashog's Avatar
ford390gashog
Originally Posted by robdog6942
Hey Guys & Gals,
Well H13 bulbs tend to explode if power is applied to both filaments. So your saying all four lights run low and high at the same time? There is four bulbs in use on these trucks not two.
Tdunn65
May 3, 2020 10:07 AM
Wvstream71
Aug 8, 2017 05:54 AM
70_F250_390
Feb 18, 2011 10:15 AM
Graeme
Feb 20, 2009 10:17 PM
fordman363
Aug 31, 2006 01:16 PM
