Fuel pressure issues
Old Apr 29, 2021 | 11:25 PM
andrewrandall01's Avatar
andrewrandall01
1986 f150 v8 5.0 Lariat XLT (Back tank deleted)
Hey everybody im clueless once again,
Been doing lots of repairs and maintanence checks everywhere to get it street ready, and a lingering issue since i bought the truck is fuel pressure.
At first fuel pressure was fine but would bleed within a minute, so went through and did the lines again and finally stopped the bleeding. Recently truck has been starting very very slow (like 10 psi eventually getting to 30 while cranking)
and finally i went through and checked the pressure again and it was rough. With about 6 primes it can get to the fuel pressure needed, and when i crank the pressure builds up to about 40 to run. I have replaced and tested
the intank pump and its problems, injectors have been replaced and recently replaced fuel filter. The high pressure pump runs, havent tested if it "really works" but it does run and moves gas. Back tank is deleted so the line of fuel goes
Tank- low pressure- high pressure- fuel filter- fuel rail- fpr- tank
There is a smell of gas out of the fpr, but i really dont think that is a reason since the rail isnt loosing pressure, even though the fpr isnt probably at its best. Might of missed some info so feel free to ask,
Hope someone can help,
Andrew
Old Apr 30, 2021 | 06:54 AM
Franklin2's Avatar
Franklin2
So the engine runs fine? It just cranks excessively after it sits? And you checked recently and the fuel pressure is dropping fast after the engine is turned off?
Or is the problem the pressure is low after sitting for awhile (can be normal), but you are complaining the pressure is not building up fast enough?
Old Apr 30, 2021 | 12:44 PM
andrewrandall01
Hey Franklin,
Yes, the pressure barely barely builds up on prime (within 10 psi), but also has led to some running shutters and such. Idle surges up and down but eventually the idle will come to a stand still (Dont think thats really a fuel symptom). The engine runs pretty well but when starting it coughs gas and has a really rough time turning over, after it does come on it surges in rpms in within 5 mins or so the idle comes down (also dont know if that is a symptom). And no, even with built pressure in the rail the cranking is excessive, and after i run it for awhile (engine hot) it barely wants to start at all. All ignition has been replaced and adjusted (besides timing). So i am kinda at a loss, but overall yes the prime only moves the guage within 10 psi and is causing some running issues somewhere. After i run the engine and turn it off it loses 5-10 psi and then holds 20-30 for about 15 minutes.
Thanks, Andrew
Old Apr 30, 2021 | 01:33 PM
andrewrandall01
Update:
Psi after priming maybe built up about 5 psi after every prime with the high pressure weazing pressure. BUT what i found is that after 3 or so primes the wheezing stopped and the fuel pressure shot up like there was air in the line.
I going to go through and check all my lines for leaks or whatever it could be but im thinking since my high pressure went from screaming to almost no sounds i think i have an air bleeding issue. ALSO psi bled about 15 psi after i turned the key off if that means anything to anybody.
Old Apr 30, 2021 | 02:05 PM
Franklin2's Avatar
Franklin2
I am trying to zero in on one serious problem. I guess that would be not starting hot. I would not monitor and wonder about the fuel psi until it will not start. If you have good fuel psi and it will not start, you have some other problem besides fuel psi.
So the next time it won't start, check the psi and then check for spark.
Old Apr 30, 2021 | 02:13 PM
andrewrandall01
From what ive read i am assuming my starter is just not enough of a jump, battery is 750cc with a 65, so it has to be the starter. All engine components have been tested and rewired. But yea i will go through and make sure there isnt any obvious leaks and just clean all of it and let everyone know of any solutions.
Old Apr 30, 2021 | 05:25 PM
FuzzFace2's Avatar
FuzzFace2
Originally Posted by andrewrandall01
Update:
I see it as a fuel PSI thing.
What should the normal PSI be with just turning the key on - prime just 1 time?
Are both low PSI & high PSI pumps to run when priming?
What should the running PSI be?
If the fuel PSI is not there, no gas, how will it start / run?
Now if the fuel PSI was there then I would maybe look into the wiring to the injectors.
Dave ----
Old Apr 30, 2021 | 06:17 PM
Franklin2's Avatar
Franklin2
Dave ----
See what I mean from the previous post? Sounds like it won't crank over hot. It's not going to start if it won't turn over. Too many things going at once. We need to divide and conquer the most serious ones first I think.
Old May 1, 2021 | 07:10 AM
FuzzFace2's Avatar
FuzzFace2
Hey Franklin,
Thanks, Andrew
Well lets get it to prime / build fuel PSI when cold then move to the hot no crank.
What if he is cranking it a lot to build fuel PSI and over heating the starter and it is just wore out now?
I think he needs to disconnect (electrical part) the 2 pumps (low & high PSI) to see what happens.
It should not build any PSI at all.
Then hook up the low PSI pump and see if when priming it builds any PSI.
May even want to remove the fuel line out of the pump to see if he is getting anything when priming.
If that checks out after a few tests do the same to the high PSI pump.
I am guessing that 1 or both pumps are having issues when trying to prime the system and he needs to find what one it is and that is the only way I know of testing.
Once he can get the fuel to build PSI every time when priming then we can look into the hot no crank as we should be able to start the motor every time being it now has fuel PSI.
But thats just me LOL
Dave ----
Old May 1, 2021 | 09:38 AM
kr98664's Avatar
kr98664
As much as it pains me, I must agree with Dave. I've been following along from the bleacher seats, but I have a headache trying to understand exactly what is happening. I think the terminology being used is muddying the waters. I keep hearing "crank" and "start" and "turn over". Those terms can mean different things to different people. How about we stick to definitions like the following?:
Crank: The ability of the starter system to spin the crankshaft at a healthy speed so the engine can then start. This cranking speed needs to be reliable under all conditions, regardless of whether the engine actually runs on it own when the key is released from the Start position. Is the starter cranking speed good at all times? This is a basic prerequisite to get the engine running. It will do no good to spend lots of time and effort on the fuel and ignitions systems if the starter system can't get the crankshaft spinning first at the proper speed. "Crank" can also refer to a crabby old guy who tends to split hairs in online forums.
Start: What the engine does once the starter system spins (cranks) the crankshaft at a good speed. Fuel is delivered, ignition takes place, and the engine now spins the crankshaft without any help from the starter.
Turn over: A flaky pastry with a fruit filling and light frosting. Mmmm! Goes really well with hot coffee served by a cute young waitress with Daddy issues.
Old May 1, 2021 | 06:28 PM
diggerrigger's Avatar
diggerrigger
Regarding the fuel system in this 1986 5.0L EFI:
When the key is turned to the on position, the in-line high pressure pump runs for a timed cycle controled by the ECM (computer). The cycle is normally no more than two seconds. At this point the pressure in the rail should be at least 30psi. The pressure should not drop at all if the key is turned off. If pressure drops, the #1 most likely cause is a failed check valve at the high pressure pump discharge. Less likely causes for pressure dropping are fouled fuel flow valve (FFV, commonly also called fuel pressure valve) or ruptured diaphragm in FFV. Also, fuel injector can be leaking. All three less likely causes will show a steady loss of pressure all the way to minimum pressure. Normally about 3psi. The failing high pressure pump check can allow pressure to drop at any rate, stop dropping at any pressure.
The OP does cite possible air issue with fuel system. The entire fuel delivery system is designed to be completely full of fuel at all times. In a perfectly operating system the pressure between the HP pump and FFV would never fall below 30psi. Specs say pressure should hold at 30psi or above for twenty minutes. The primary side of the fuel system, the low pressure tank pump loop normally holds about 3psi.
OP says one tank has been deleted. One might assume that the two now unused ports at the six port reservoir were simply disconnected and capped. I do not know if this could cause the reservoir to siphon empty, fuel draining to tank. I doubt it though. Easy enough to check. Unscrew reservoir cap from the parked overnight truck.
Note: I plan to delete my truck's side tank. I bought a four port reservoir ($70) for this.
My view: If the primary loop is full of fuel, the most likely culprit is the HP pump and its integral check valve.
OP says FFV smells of gasoline. Test: disconnect vacuum source and build fuel pressure. If the FFV diaphragm is leaking, you'll get fuel running out of the vacuum connection port.
rdunagan
Jan 28, 2022 12:40 AM
nickpierce
Jul 8, 2007 07:14 AM
mrgn_mtt
Jun 25, 2007 04:57 PM
specialist484
Jun 6, 2007 11:32 PM
jnickles
Jun 10, 2006 03:16 PM
