Electrical system dead
Old Apr 26, 2021 | 11:03 PM
ScanmanSteven's Avatar
ScanmanSteven
2019 F350 6.7 diesel, 34,xxx miles. We drove the truck yesterday, made about 10 stops, visiting and shopping. Got home and decided to wash the truck exterior. After washing it got in to move it to the shop, electrical system totally dead. No light, no ding w/key in, door open, no instrument panel lights, no horn and no start. Opened the hood, checked battery voltage, 12.5 +/- on both batteries. Unhooked both batteries for 30-45 sec and reconnected, everything fine, started right up, everything fine today. So just a random gremlin? Called dealer, he said they have heard of it, didn’t seem concerned. If it keeps happening then bring it in. Opinions?
Old Apr 26, 2021 | 11:50 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You'll always get about the same voltage reading on either battery because they are connected together.
As to the cause of the failure...no idea???
Old Apr 28, 2021 | 09:21 AM
sauerkraut1's Avatar
sauerkraut1
Don't know what but something got Wet .. Did You spray the under side of truck ??
Some folks use spray cleaner in the engine compartment then hose it off ??
Old Apr 28, 2021 | 11:31 AM
mhoefer's Avatar
mhoefer
Drivers side battery needs to be checked, its what gives the voltage and inside voltage was probably under 12.5, even 12.4 volts will be a no start. One bad cell in either battery most likely due to age of these batteries, be sure to replace both with same lot/batch.
Old Apr 28, 2021 | 11:37 AM
ford390gashog's Avatar
ford390gashog
It's time for new batteries, have yours started leaking yet?
runwayz
Nov 19, 2019 05:09 AM
KMG2010
2009 - 2014 F150
Oct 25, 2019 10:52 AM
12valveEx
Aug 16, 2013 08:24 PM
rackhound
Arizona Chapter
16
Jul 25, 2010 01:05 PM
pc09123
1983 - 2012 Ranger & B-Series
Feb 15, 2009 07:49 PM
