Need some help (cooling)
Truck: 2000 V10 4x4 Limited, stock engine/exhaust except the SCT tuner.
Last summer I was pulling our 7500lb S&R trailer (from Chico to Sacramento - flat roads)...it was in the high 90s...about 5 miles from Sac the engine kicks into limp mode, temp was pegged, SEL came on (code was cylinder head overheat - can't remember which one). Pulled over, swapped the trailer to another rig, and limped it home. I suspect I lost my fan clutch. Replaced the thermostat, fan clutch, water pump. A few days later, the radiator springs a leak...replaced that as well. Truck ran fine but I was only towing on the flats.
I have an SCT and the coolant temps run about 202 on average...only once in a while to I hear the fan clutch engage. When the first issue happened I had the SCT programmed with the 87 power tune.
On Thursday I pulled a different trailer (again around 7500lb) from Sacramento to Portland, still with the 87 power tune. My eyes spent more time on the coolant temp than on the road. Temps were in the 60s in the AM, high 70s/low 80s in the evening. On multiple long inclines, I would get a temp warning light and the gauge would peg, but the SCT would be reading 208, 210. No SEL light.
I was able to make the run (although I grew a few more grey hairs on the longer inclines)...I'd run in normal drive until I hit around 60, then I'd kick off the OD...then if I dropped below 45-50 I'd drop it into D2.
I noticed at higher RPMs I'd see the coolant temp drop (but of course the oil temp rise). More water = more cooling...but still I rarely heard the fan kick in...usually around 208-210, but one peak at 214 and I still didn't have the fan clutch kick in.
On my way back, it was light rain and temps in the high 40s. Put the SCT into 87 tow. No warning lights on the way home, but temps still maxed at 214, fan rarely kicking in. It went down to 38 degrees intake air temp at one point (rain/sleet/snow mix) near Mt. Shasta, temps there were down to 198 on the downhill grades, 208-210 on the uphill grades.
On the Sacramento Valley floor temps averaged 208-210 (had some headwind) but intake air temps were in the high 60s/low 70s.
I'm feeling like something is still wrong with the cooling system. I'm not sure when the fan should be kicking in, but I think it's barely doing it's job. If the fan IS kicking in at the correct temps, I have no idea what else could be wrong (considering a new thermostat, new fan clutch, new pump, new radiator).
Question 1: How can the coolant warning light/gauge kick in at one temp on the way up and not at that same temp on the way back? Are there multiple coolant sensors on the motor?
Question 2: What temp should the light be kicking on at?
Question 3: Around what temp should I hear the fan kick in? I know it's hydraulic, but I would think they would be around the same temp from one to another.
Any ideas? I'm wondering if I should just find a non-clutch fan and let it run all the time, but I don't know if they even make them for our motor.
On a side note (and unrelated I think)...I had an oil pressure sensor go out on me recently (after the cooling system died but before this trip to Oregon). I had oil all around the sensor back to the exhaust crossover and you could smell the oil burning on the exhaust pipe.
I replaced it and immediately had that one start leaking (but far less). Took it to a shop and they said it was a cheap sensor. They put in a Motorcraft and it was fine, but they did say they think I have either an oil pan gasket leak or a main shaft seal leak...they put in dye to the oil so they can look at it again. Underside looks like a class 1 leak, however I do occasionally smell oil on the exhaust after a hard run. No drops on the ground.
I doubt the oil is any relation to the cooling system issue but figured I'd put it out there. And for anyone wondering, the shop is quoting around 3k to replace the oil pan seal, and another $200 for the main shaft seal (might as well do that if the motor is halfway pulled out to do the oil pan gasket anyway). Sounds like robbery to me but I can't see any other way to get the oil pan off than to pull the motor up a few inches.
Any ideas folks? Appreciate any suggestions at all!
I have a Torque Pro setup and i am able to track the coolant, Trans, and cylinder head temps all on screen.
1. You might have air trapped in the heads, park the truck on a strong incline is the easiest way, so that all the air heads to the front and ends up in the radiator, i had this problem on my 07 GT, temps were doing odd things, to i drove it up a dirt berm and e-braked it, and was able to pop the hood and burp a bunch of trapped air out of it that i never knew was there, on the Ex, jacking it up might not be an option, but if you have a 30ish degree incline somewhere such as a pile of dirt, or something, it might prove useful, but this is a guess, vacuum filling the cooling system would help eliminate this as a cause.
I'll look at finding an incline also. The foothills are just a half hour away, I'm sure I can find something. Do I want to idle on the incline first, or just get it up and shut down the engine / let it cool / burp the housing at the thermostat?
Aluminum Temperature to Strength chart, by the time you get to 150"C = 302^F You have potentially lost a massive amount of strength in the material
Keeping the CHT temps between 212^F (100^C) and 240^F (115^C) is a realistic target that can be maintained, and means you retain almost full strength in the materials, meaning no warped heads, cracking from heat stress, etc....
Coolant temp averages between 185-220, usually on the lower side, unless again im sitting parked for a long time, with the ACs full power etc. but even then, since i have fixed that pipe, and closed the two little holes on the side of the filter housing, it has not built up temps as fast as it used to, those made a big difference in its heat buildup when sitting.
Note that i have a 180F thermostat also, which helps get it open sooner and keep the CHT temps down lower. Lots of people dont understand that the Heads can actually be hotter than the coolant is and by the time the coolant gets to the point it opens the factory thermostat fully, the heads are actually surpassing the coolant temp by about 25-35 degrees, at least here in arizona that is. So by getting the thermostat open sooner, at lower temp, the CHT has actually stayed lower as well. Again i believe that may be different if your not in a super heated climate, here in arizona its a winning combo.
The above chart and temperature information is from reference of Michael LaRosa, B.S. Metallurgical and Materials Engineering & Economics, Case Western Reserve University
