1966 - 1977 Early Broncos
9" lube level - no fill plug
Old Apr 26, 2021 | 11:48 AM
wgb's Avatar
wgb
I have a modified 9" in my '71 Bronco. It has no fill plug in the third member. Is there a way to check the lube level/add lube using one of the pinon bolts?
Or some other method?
Old May 13, 2021 | 12:37 AM
Boba Fett's Avatar
Boba Fett
Usually there is no fill plug on the 9" housing - on the back side that you see. Most of the 9" housing with one are either aftermarket or the bung has been welded on. On the actual third member, the chunk, there will be a fill plug IIRC located on usually the drivers side that is an internal hex plug.
Usually that plug is stubborn to remove. An impact really helps with getting it out.... also hit the threads a while with 3 n 1 oil to loosen them.
Old May 20, 2021 | 04:09 PM
bulletpruf's Avatar
bulletpruf
You likely have a '66 third member in a later housing. In '66 (and maybe '67?) the 9" housing had the fill plug not the third member. It flip flopped after that. So with an early chunk and a late housing, you have no way to add fluid.
Old May 20, 2021 | 04:15 PM
ford390gashog's Avatar
ford390gashog
Only way to add is from the vent hole on the axle.
Old May 20, 2021 | 04:39 PM
bulletpruf's Avatar
bulletpruf
Excellent point. Of course, figuring out if it's at the right level won't be easy, assuming you're not starting with a completely empty housing.
Old Jan 2, 2022 | 07:46 AM
manicmechanic007's Avatar
manicmechanic007
I had the same problem
Sure you can add gear oil thru the vent but how much you gonna add?
Best to remove the 3rd member and drill and tap for a fill plug
Ignorant job but you only have to do it once
That is the only way you can get the level correct
Old Jan 6, 2022 | 09:45 AM
andyh1956's Avatar
andyh1956
You could remove an axle & flip the truck up on it's side & fill from the housing end. Stop when lube runs from the vent hole.
Old Jan 8, 2022 | 12:23 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I guess I need to get under some other Bronco's, I thought they all had one on the dvrs side of the 3rd member chunk. Fluid check, grease u joints and then an underside nut & bolt ck. Before hitting the trails.
bigcountry1009
Mar 26, 2015 03:02 PM
richardbrust
15
Feb 23, 2014 07:36 PM
jjurva!
Jul 26, 2013 01:13 AM
currituckF150
Apr 7, 2008 11:13 AM
masterp2
Jun 24, 2004 08:58 PM
