Differential fill plug HELP!
Old Jun 24, 2004 | 08:45 AM
masterp2's Avatar
masterp2
I am looking at the 10 bolt diff cover on my 97 Expy 2wd. It is leaking and I want to check the level. WHERE IS THE FILL PLUG? fOR THAT MATTER WHERE IS THE DRAIN PLUG. I don't get it, no plugs.
Old Jun 24, 2004 | 09:55 AM
buzzard's Avatar
buzzard
No drain plug. To remove the fluid, loosen the bolts and pry the bottom of the cover off. The oil will drain out.
Old Jun 24, 2004 | 11:18 AM
masterp2's Avatar
masterp2
thank you!!!
Old Jun 24, 2004 | 08:57 PM
BlueBobbyBird's Avatar
BlueBobbyBird
Shouldn't there be a fill plug on the driver side of the case, just above the cast web?
Old Jun 24, 2004 | 08:58 PM
masterp2's Avatar
masterp2
Found it thanks.
