72 F100 power steering conversion help
Old Apr 25, 2021 | 09:02 PM
zims23's Avatar
zims23
Hello,
I converted my F100 390 4spd to power steering. I shortened the column according to instructions on this forum. I sourced a 74 PS gear box. My only issue in the column doesn’t align perfectly to gear box. I read about this and a common answer is Cab mounts, mine are solid. I also read column bracket on firewall is different between manual and PS trucks. Has anyone had to swap the column mounting plate? If so, can I use from a dent?
Old Apr 25, 2021 | 11:26 PM
Christmas's Avatar
Christmas
The bracket on the end of the column you need will come from a PS truck and will say PS on it. You really need it. The rubber firewall gasket on the inside will need to be moved up or modified to fit. Have you read this.
How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
Old Apr 26, 2021 | 07:43 AM
zims23's Avatar
zims23
Thanks for this. Yes I read that sometime ago and used that information to assist in modifying my column. I missed the section on the firewall bracket. I will now try to source one. Thanks.
wallyworld
Dec 2, 2014 04:34 PM
sullyda1
Jan 11, 2013 06:03 PM
ynkstr
May 14, 2008 04:37 PM
juchertf100
Mar 30, 2007 10:15 AM
whomrig
Apr 21, 2001 09:48 AM
