HELP! 88 Bronco 2 Idle Surging Issues
SYMPTOMS:
-Cold start idles up to 2k RPM, then then drops down and surges up and down
-When surging, it gets real low and will cut out after about a minute
-have to keep reving it to keep it runing
-when I put the truck in gear, it will idle back up high and stay running
-engine light will blink for a few minutes
-when in gear running, engine is fine. When stopped, engine idles fine
-after it warms up, it will idle fine.
Here are the codes I am getting from my scanner, and what the book that comes with the scanner calls them out to be:
(KOEO CODES)
31 - EVP or PFE circuit below min voltage
31 - EGR valve control sensor fault
31 - EVAP control system below min voltage
84 - EGR Vac regulator circuit failure
84 - EGR Vent fault
89 - AXOD Lock up solenoid (LUS) circuit failure
KOER CODES:
25 - No knock sensed during DRT
74 - Brake on/off (BOO) switch fault - closed circuit (funny my brake lights work fine)
No replies yet, so will see if I can get things started. Good idea to have scanned for & posted All trouble code clues.
SO, lets think about this some more.
EGR isn't used at idle after a start, so isn't likely to be guilty of idle woes, BUT the EVAP system is used at cold start-up & you have trouble codes for that system, so concentrate your idle quality trouble shooting efforts on that system & remember we are to work & put right the Lowest code number first. Since you have a low control ref voltage code, I'd begin with that & since the engine computer is the source for the 5 volt reference, back probe the ECM electrical connector to see if its there, as it controls All systems. If not, or its low, suspect the ECM. If ok there, suspect a wiring run, or electrical connector problem. Seeing as how you say its low mileage, suggests its sat somewhere for a while & mice like to chew on the wiring insulation so keep that in mind.
Also since this is a Vintage ride, dry-rotted vacuum lines & rubber fittings & maybe a mucked up IAC, belong on the suspect list too!!! A bunch of beginning thoughts for consideration, let us know what you find.
