Flathead running issue
Old Apr 25, 2021 | 04:04 AM
jeremo's Avatar
jeremo
Hi all!
I am trying to fix my 53 flathead V8 for a long time without any success so far so I am reaching out you guys !
The engine is starting, runs normal first. After 30 seconds, the engine tends not to run with all cylinders and then shut off.
First, I thought about a fuel pump issue. I have rebuilt the original mechanical pump with new valves, diaphragm and gaskets.
I can see a few (not many, just a few sometimes) bubbles in the hose between the fuel pump and the carburetor.
I have also rebuilt the carburetor with new gaskets, new power valve.
I checked the spark plugs, they are all very black, so the engine is running rich.
I have replaced the distributor rotor, changed the condenser. New spark plugs wires. The coil is also new, 1,3 ohm, I don't have a resistor.
The engine revs fine most of the time but sometimes I press the throttle and the engine dies and then revs up. I haven't checked under load, might be an issue.
Anyways, the engine dies a bit later even after reving it up, it ends running badly and dying.
I have added an electric pump in line with the mechanical pump and I am not sure how to consider the progress since the truck still doesn't rev up smoothly and dies.
When it dies, I just need to restart the truck and it's running fine.
My timing is set to 0 degrees when the vaccum is disconnected and 1 degree when vaccum line connected.
Please help me since I am now out of ideas... :-)
Old Apr 27, 2021 | 10:13 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Hey, Jeremo! Welcome to FTE.
You will find a host of flathead folks at the 48-56 forum. 1948 - 1956 F1, F100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums (ford-trucks.com)
Not as many people come to the flathead forum. I guess they are more interested in the overall truck than just the engines.
yosemite98
130
Aug 14, 2019 02:45 PM
1=2
64
Feb 12, 2009 10:05 PM
cougarless
Mar 8, 2007 06:26 PM
Jekylltamer
Oct 3, 2004 08:25 PM
JamesH
Feb 7, 2003 03:32 PM
