Sponsored by: Real Truck
Starter trigger wire only 5V
Old Apr 24, 2021 | 10:09 PM
skiastro's Avatar
skiastro
Hello Everyone,
I drive a 2000 F-250 5.4 and recently done a deep cleaning of the center dash..ie I took everything apart & washed it down (mold outbreak due to broken windshield). Once I put everything back together and turned the key to nothing.
Checked battery, starter, starter solenoid(relay), fuses & relays in boxes, starter switch & key, and the NSS. Nothing came back as the issue.... except I was only getting 4.75 V (~4.85V when key on start) coming from the starter trigger wire on the solenoid.
Figured since I wanted to see if there was any error codes popping up with the engine on I jumped the solenoid to get the engine running.... No codes...No lights...Only thing different was this occasional beeping that wasn't caused by the door being open.
Turned engine off & reattempted to turn back on but still nothing.
Was wondering if I forgot to plug in something that was causing a safety "switch" to disable the engine unless this was plugged back in.
Anyone know either a list of these safety switches so I could double check them? or know what the problem is?
Old Apr 25, 2021 | 09:06 AM
Djosbun's Avatar
Djosbun
Get a wiring diagram for the ignition switch and grab a test light. Work your way backwards, following the wire diagram) at each connector that carries the + ignition switch wire (while also checking the ground). You'll eventually find the connector that probably has green crusties in it or a lose pin.
-- Dave
Old Apr 25, 2021 | 12:07 PM
projectSHO89's Avatar
projectSHO89
The ~5 volts is essentially "noise" being backfed from either the radio or GEM module. It's only meaning is pertinent is that your starter trigger electrical circuit is out to lunch.
Start by checking CJB fuse F20. It should be HOT IN START. If not, the problem is back at or to/from the ignition switch or its feeds.
smashclash
47
May 11, 2023 09:04 PM
Roller150
20
Aug 4, 2015 10:28 PM
seizure911
Feb 17, 2008 10:54 PM
cshook1
May 30, 2005 06:24 PM
skipy
Aug 24, 2003 08:31 PM
