water temp probe location
Old Apr 23, 2021 | 07:20 PM
texasjack's Avatar
texasjack
Where would I find the water temp probe location on the block for a Auto meter gauge I have? Cant use location neat thermostat ,probe too long.. thank you!
Where would I find a location on block for engine coolant probe for a auto meter gauge????
Old Apr 23, 2021 | 08:10 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
I assume you are talking about the 7.3. Your truck water temp probe for the dummy gauge on the dash is on top of the water pump. If you want to add a separate probe for another gauge you can do that on the side of the water pump below the thermostat housing. Look for the thread in fitting and remove it. I believe if I remember correctly you will need about a 3/8 Allen wrench to do it..
Old Apr 23, 2021 | 08:49 PM
Colorado350's Avatar
Colorado350
I installed in the coolant filter housing I got from Riff Raff Diesel. I think you could install it in the water pump plug...I don’t remember how long the probe is though.
Old Apr 24, 2021 | 12:49 AM
FinnishStroker's Avatar
FinnishStroker
There is cut-to-lenght temp senders available.
Don't know is there any that fits Autometer.
Old Apr 24, 2021 | 07:08 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
There are a couple of options, perhaps you can provide us with the overall length measurement of the probe that is inserted into the coolant passage.
If it is abnormally large or shaped, you may need to go a different route.
You don't have a 2001 or younger ZF6 by chance do you?
Old Apr 24, 2021 | 09:54 AM
texasjack's Avatar
texasjack
The probe extends 1.75 inches and is too long to be used on the plug location near thermostat
Old Apr 24, 2021 | 10:35 AM
Colorado350
The housing that holds the filter has 3 threaded ports. The probe screws into it...
https://www.riffraffdiesel.com/riffr...ter-kit-99-03/
Old Apr 28, 2021 | 10:51 AM
texasjack's Avatar
texasjack
holds filter?
Old Apr 28, 2021 | 02:38 PM
Sous's Avatar
Sous
FTE Emeritus
holds filter?
It seems Colorado350 used the 3rd port on his coolant filter housing and that is what he is recommending you do. It appears you do not have this filter system and so the option of using the housing is not possible.
Here is a picture of his installation as a visual aid.
Image source: https://www.ford-trucks.com/forums/5...l#post17580691
In that same thread, SkySkiJason says the following about installing a coolant temperature sensor.
Ive installed aftermarket temp senders in the drivers side block drain location. That is a 1/4” NPT fitting. I prefer this location for cleanest wiring - where I can bundle/loom these wires with the EGT and trans temp wires as they head toward the firewall penetration.
That said, the only reason to add an aftermarket coolant temp gauge is if the stock gauge doesn’t work at all. We can easily use EOT as a gauge to monitor if the engine is up to operating temp and if there is a problem with cooling system. Monitor EOT with OBD2 using tools like Scangauge2, ForScan, etc.
Quote source: https://www.ford-trucks.com/forums/5...l#post19579961
Hopefully this helps you complete a simple project gone difficult...
dennisb56
Mar 16, 2012 05:19 PM
993/4ton
Modular V10 (6.8l)
Nov 12, 2006 12:27 PM
89broncobob
1978 - 1996 Big Bronco
Jul 6, 2003 07:08 PM
