Engine help
Old Apr 23, 2021 | 04:16 PM
Tclemens2's Avatar
Tclemens2
Engine help
Hey guys,
Recently I had a few exhaust leaks so I fixed them and in the process I put in a new gas tank and sender unit in. The truck had been sitting for about 2 months not running, and when we went to fire it up it started but it won’t idle. When I give it gas it seems very laggy and it has more of a hissing sounds then usual and I can see a little bit of the gas shooting out the carb when you hit the throttle. What should I be looking for and what could the problem be? It’s a 1973 f100 automatic with a 360 5.9L
thanks!
Old Apr 24, 2021 | 11:30 AM
LONCO's Avatar
LONCO
I’m no expert but, sounds like it might be multiple vacuum leaks. That’s where I would start. Maybe hoses or gaskets dry rotted while sitting??
Old Apr 24, 2021 | 01:47 PM
smle's Avatar
smle
Where is the gas shooting out of the carb coming from? Accelerator pump? Bad situation there. That's a fire waiting to happen.
Lonco is right a lot of your problem sounds vacuum related. But get the carb checked out first.
BendF100
Oct 4, 2018 09:16 PM
roboto65
Feb 2, 2017 09:49 AM
quinletc
Nov 4, 2014 06:15 PM
hannahbarie
Texas Chapter
Mar 16, 2010 05:12 PM
D-Rock23
Jan 26, 2006 07:55 PM
