Sponsored by: Real Truck
electrical question
Old Apr 23, 2021 | 03:30 PM
rayxxxle's Avatar
rayxxxle
4wd Low
electrical question
2014 f250 super duty gasoline 4 door
Driving down the road and used the switch to open the rear center glass, courtesy light in the roof console came on, and all dash lights dimmed to nothing with light switch on auto. Turned lights off, dash lights came back on but overhead courtesy lights stayed on.
Any one have an idea on this?
Thanks, in advance
Old Apr 24, 2021 | 12:10 PM
rayxxxle's Avatar
rayxxxle
4wd Low
Well, went out this morning, and everything was working right. Appears it happens after opening and/or closing the rear window.
Old Apr 24, 2021 | 01:24 PM
Gyppo Logger's Avatar
Gyppo Logger
Sounds like you have a short, your roof leak at all? You have cab running lights at all that might cause a leak? Was it raining that day or did you wash your truck?
Old Apr 24, 2021 | 03:03 PM
rayxxxle's Avatar
rayxxxle
4wd Low
No roof leak, had been raining. All outside lights work when this happened. This happened once before, and I think both times I had opened and closed the rear window.
Thanks for responding.
Old Apr 24, 2021 | 07:07 PM
Djosbun's Avatar
Djosbun
Check a wiring diagram to find the connector for the rear window motor. You probably have corrosion at the connector (green crusties) causing voltage back-feeding the dome light.
-- Dave
Old Apr 24, 2021 | 09:08 PM
rayxxxle's Avatar
rayxxxle
4wd Low
Thanks, will do.
Darrellt
15
Oct 27, 2017 09:35 AM
3504x4
Jan 24, 2014 12:37 PM
Shake-N-Bake
Oct 25, 2011 07:42 PM
matt14
Sep 21, 2011 09:54 AM
