Upfitter switches 1-4 timeout?
Old Apr 22, 2021 | 04:31 PM
Squirrel13's Avatar
Squirrel13
I know that 5-6 can be set for hot all the time. I was wondering if 1-4 are tied in to the accessory delay> I would like to have 1-4 power some charging ports for gps camera phones etc. I believe in Forscan I can change the timeout for the acessory ports and was wondering if that has any impact on upfitter 1-4 or are 1-4 tied only to run?
THe end result is I would like the accessory timeout to to apply to 1-4? any thoughts?
Old Apr 22, 2021 | 06:20 PM
nuctrooper's Avatar
nuctrooper
1-4 are tied to ignition status. No easy way I know of to time them from the accessory delay. You could rewire the relay block with a new power input. Pull a line off the accessory outlet to trigger a 100A relay, and power the block from that. Otherwise, as soon as the truck is turned off, upfitters 1-4 (and 5,6 of configured) turn off.
Old Apr 22, 2021 | 08:11 PM
Squirrel13's Avatar
Squirrel13
Thats what I figured. The good news is the USB plugs don’t show any 12v current draw until I plugged in my phone. I think I will just run one of the 40A upfitter to a small small 4 position fuse block and fuse each of these about 5A
Sharkhunt
Mar 24, 2020 10:12 PM
BillRes2
Dec 22, 2019 04:39 PM
JasonB1
Jan 10, 2017 02:45 PM
stewcon
Oct 24, 2006 06:32 AM
rv7today
Electrical Systems/Wiring
Dec 3, 2005 09:51 PM
