Slip Joint Grease fitting
Old Apr 21, 2021 | 08:59 PM
PossumTruck's Avatar
PossumTruck
I did my 3 U-joints and support bearing last weekend. The collar deal on the slip joint was basically disintegrated, and I needed a BFH and heat to get the joint apart.
So I cleaned it all and greased it when it went back together - and it slips again - but longer term: Can I get a new one of those zerk-collar-greaseamabobs to protect/re-grease the joint? I don't even know what they are called.
Thanks-
Old Apr 22, 2021 | 05:59 AM
Franklin2's Avatar
Franklin2
Not sure if they are even available. What I have done is buy one of those universal colored shock boots, and use wire ties to fasten it over the joint to keep the dirt and water out. You can then pack it with grease by hand. A lot of those joints don't even have grease fittings.
Old Apr 22, 2021 | 06:27 AM
PossumTruck
Thank you. I saw newer joints on various makes have boots like that, and considered it. Sounds like that might be the way I go.
I definitely packed the thing with marine grease, but my OCD won't let me forget it/leave well enough alone.
Old Apr 22, 2021 | 09:50 PM
matthewq4b's Avatar
matthewq4b
Thanks-
Just drill and tap for a grease zerk and grease at oil changes like your other zerks. Put the zerk in the same approx location as below. You really do not want the zerk on the collar anyway. And new collars and seals are available for most applications.
fomoconut
Jan 6, 2011 06:03 PM
slim pickens
Apr 26, 2008 07:59 PM
barnbridge
Oct 30, 2007 06:23 PM
Benny2002
Sep 8, 2007 04:52 PM
