Greasable (zerk) slip joint?
Old Apr 26, 2008 | 07:55 PM
slim pickens's Avatar
slim pickens
I have the driveshaft 'klunk' that I am 95% sure is a slip joint that needs grease. As much as I cant wait to tear it off and grease it, has anyone drilled and tapped the outer part to put on a small zerk fitting? I am a little concerned about imbalancing the driveshaft, so I am considering drilling 2 holes opposite of each other (12 o clock and 6 o clock) and putting on 2 zerk fittings, even though only one is needed. Am I reinventing the wheel here?
Thanks,
SP
Old Apr 26, 2008 | 07:59 PM
Monsta's Avatar
Monsta
Sit. Stay.
I know someone has done it, I just cannot remember who.
I wonder if the weight of the material removed would be the same as the fitting negating the need for two...
JohnnyAirtime
Apr 14, 2016 05:43 PM
gothicman02
Aug 18, 2014 06:15 PM
Powerstoke73
Aug 2, 2014 04:00 PM
EXv10
Jun 18, 2009 11:15 AM
Budman1962
Mar 20, 2008 11:50 AM
