Need Forscan help
Old Apr 20, 2021 | 12:50 PM
Watermain's Avatar
Watermain
Need Forscan help
2020 F350 XL without cruise. I bought and installed a new steering wheel with cruise.
In forscan I enabled cruise in the BCM. I tried to enable cruise control switch in IPC but it wouldn't let me. I tried changing SCCM 724-03-01 xxxx-xxxx-x2 to 3 since I found that someone on the forscan forum said that worked, Nope. I am out of ideas. Does anyone know what I am missing or doing wrong?
Old Apr 20, 2021 | 12:59 PM
ford390gashog's Avatar
ford390gashog
Check the BCM.
Okay it's been a while since I did this but I remember there was this change. I could be wrong.
BCM
726-13-01 8084 6045 00EA
726-13-01 8088 6045 00EE
Old Apr 20, 2021 | 01:11 PM
Watermain's Avatar
Watermain
I was off by 1. The change in the SCCM is 724-03-01 x0xx-xxxx-x2 to x1xx-xxxx-x3.
Now it works.
NM6.2
Aug 1, 2025 11:07 PM
Andrew Cortese
Mar 16, 2021 11:19 AM
96_F250_Deezal
Jan 3, 2018 10:25 PM
GuitarJesus
Jun 26, 2012 08:54 AM
packratF350
Electrical Systems/Wiring
May 15, 2004 01:31 PM
