dead hydra box
Old Apr 19, 2021 | 04:29 PM
oldbird1965's Avatar
oldbird1965
dead hydra box
Took off yesterday for our annual six month cross country trip and before I was a block away from our house I noticed the hydra #5 position number (that I use alot) was only half lit. It was like most digital lights left in the sun starts to act up. Of course I had to start playing with it but in the end it didn't matter because it didn't move off of #5 which is my favorite towing tune. This morning, out of the sun, the little screen is blank. I can push the buttons and nothing happens. When I get time I'll check the connection on the PCM. Has this happened to any body else?
Old Apr 19, 2021 | 04:55 PM
Edgethis's Avatar
Edgethis
Hasn't happened to me (knocks on wood). I agree that you should double check the cables connections.
How old is the box? Maybe it just needs a new box. Is that an option to buy on sites?
Old Apr 19, 2021 | 05:57 PM
oldbird1965
Well Brett, I did a search and only found one and its in the form of a gauge at Jelibuilt. My switch box is six years old and I probably just need a new one. I emailed Clay and I'm waiting for a reply. I just don't want to mess with the cord and knock it off my tow tune. I have a lot of mountain grades to get thru between Vegas and the Black Hills of SD. Once in the Black Hills I'll be there for two months so I'll have plenty of time then.
Old Apr 19, 2021 | 06:25 PM
96 OBS's Avatar
96 OBS
Mine came with a similar deal from Riffraff. Half the thing doesn’t light up except for on 3 and 4 never did since I bought it. 3 and 4 light up all the way but even when I start the thing and It’s supposed to flash PHP it only does half the lights
Old Apr 19, 2021 | 06:33 PM
oldbird1965
First I heard of that right out of the box! Just writting on this thread I have convinced myself not to touch it until I get to SD.
Clay just emailed me, said he didn't have one. IDK, maybe that gauge setup would be pretty cool.
Old Apr 19, 2021 | 06:44 PM
fordman67's Avatar
fordman67
That's what I want for mine.
I have not heard of the issues you are having.
I can send you my box if you need as I'm not using it tight now.
Old Apr 19, 2021 | 07:02 PM
oldbird1965
That's pretty nice Aaron. I have a single gauge setup that I'm not using and I could put it up on the pillar column, easy to get too.
Old Apr 19, 2021 | 09:02 PM
fordman67's Avatar
fordman67
That was my thought. I would swap my 3 pod for a 4.
I like it because it looks like it belongs not just stuck there.
Old Apr 20, 2021 | 07:45 AM
TheFecalFanatic's Avatar
TheFecalFanatic
I wonder if it's the ribbon cable to the chip itself. Those are a little more common than the hydra switcher.
Old Apr 20, 2021 | 08:43 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
East Coast Diesel sells the standard hydra switch by itself.
EDIT:
Nevermind. I just checked...I must have bought the last ones they had two months ago.
Old Apr 20, 2021 | 10:03 AM
oldbird1965
You could very well be right Jake. I have the ribbon cable running up thru the fuse box door that is squeezing it.
Cleatus12r, thanks for checking on that!
Aaron-71
Paint & Bodywork
17
May 23, 2011 12:12 PM
Bodaddio
Apr 26, 2010 12:14 AM
Greywolf
Tennessee Chapter
15
Mar 1, 2007 10:51 PM
Bandit0594
Mar 24, 2005 08:11 PM
