Sponsored by: Real Truck
Electrical gremlins, here I come.....
Old Apr 19, 2021 | 02:00 PM
F150Dave's Avatar
F150Dave
Hello everyone, so, truck in question is a 08 job 2. Its an FX4 truck, leather, steering wheel controls, no nav/no power sunroof/no power rear slider. I picked up a set of OE Ford running boards (from an '16 Plati), the module and plugs (all under $500cad). I'm pretty confident they never offered prb until 11+ so, as long as the module has power and ground, will the boards operate as intended? I'm unclear on the CANBUS - and +. Here is a copy of the diagram in question.
Old Apr 19, 2021 | 09:01 PM
ifrythings's Avatar
ifrythings
The MS CAN bus is needed to tell the module what to do, you mite get lucky by hooking it up to your truck and it mite read the door status message from the CAN bus. If it doesn’t work than the CAN message changed ID address when they change truck generations (08-10), (11-16), (17+) or it needs other messages that your BCM/SJB doesn’t generate.
strtcop1
Jul 16, 2020 08:01 AM
strtcop1
May 21, 2019 09:24 PM
strtcop1
May 5, 2019 08:52 AM
strtcop1
May 4, 2019 12:21 PM
dalesatter
Jun 12, 2010 12:34 AM
