Power running boards
Old May 4, 2019 | 12:25 PM
strtcop1's Avatar
strtcop1
On the power running board module there are 2 connections called MS1 CAN + grey/orn and MS1 CAN 1 - viol/orn . It says they go to the module communications network.. Where do they go???
I'm assuming they go to the BCM , and if so , Which pins on the BCM. Or, do they go somewhere else.?
Sorry guys. still learning how to navigate this site..
Ron
Old May 4, 2019 | 05:28 PM
Mkos1980's Avatar
Mkos1980
Tap into the door signal wires. Most people use the passenger side rear door wires and run them to the module.
Old May 5, 2019 | 08:40 AM
strtcop1's Avatar
strtcop1
running board wiring
As you can see in the pic they connected to the gey/orn vio.orn in the loom. Do these wires go to the proper connection pins and are they already connected.
thanks Ron
Old May 5, 2019 | 08:47 AM
strtcop1's Avatar
strtcop1
thanks Ron
Old May 5, 2019 | 08:52 AM
Mkos1980's Avatar
Mkos1980
Already connected. Thats all you need.
strtcop1
May 21, 2019 09:24 PM
strtcop1
May 18, 2019 11:18 PM
strtcop1
May 4, 2019 12:21 PM
nxtdiesel
Apr 19, 2018 09:41 PM
bebeard
Jun 22, 2011 08:14 PM
