Power running boards initial power up sequence question...
Need help with a few questions.
I am getting ready to power up my running boards but I had heard that I should
#1 disconnect both batteries
#2 then connect the power wire for the running board module to a fused hot connection. Then,
#3 after the module is connected to a power source, connect both batteries back up so that all the modules
begin talking to each other at the same time,.
Reason: Changed title to distinguish tech question in this thread from several concurrent threads on the purchase and selection of power running boards
All i did was remove the fuse to the Amp steps, installed everything and then reinstalled the fuse. That's what the instructions said to do. Worked great
