Massive blowby?
Old Apr 19, 2021 | 01:41 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Massive blowby?
Trying to start a motor home that has been sitting for lord knows how long. ten years or better by the registration. Have a hot battery, outside fuel source, clean plugs that spark. Also have what seems to be excessive blowby. While cranking, with the oil cap off you can feel a steady frow of air with a regularly timed puff like a hole in a piston almost. Compression ranges from 80-120, with throttle open and oil in the cyls. Was fogging it with starting fluid spray while cranking and could see the mist being blown out of the4 cranckase. Am I wasting my time trying to start it to move the RV? How can I make it fire??
Old Apr 19, 2021 | 01:44 PM
ford390gashog's Avatar
ford390gashog
Skip the spray, a gas soaked rag over the intake tube should make it fire. If it doesn't then look further. While compression is low its still enough to fire.
Old Apr 19, 2021 | 02:14 PM
Thunderkiss1965
What about the blowby? Heal itself once it fires?
Old Apr 19, 2021 | 03:25 PM
ford390gashog
Well there is definitely the chance, the old low tensile rings will seat with heat.
Old Apr 19, 2021 | 05:06 PM
Thunderkiss1965
I'll give her another go tonight.
Murkin MurDock
1997 - 2003 F150
Dec 29, 2019 12:06 PM
obscurity
Feb 23, 2014 04:20 PM
Whisker
Aug 21, 2013 11:55 AM
1987_f150
23
Dec 22, 2006 08:44 PM
01 PSD
May 30, 2004 11:27 AM
