Engine won't start
Old Feb 22, 2014 | 03:16 PM
obscurity's Avatar
obscurity
Engine won't start
So today is a nice day (the first one in a little while) so I decided to take the truck out for a spin and it won't start. It ran two months ago with no protest (longest drive ever). Its pumping gas. Its getting spark. With starter fluid it will fire but not start. I rebuilt the carburetor(holley) 6 months ago and it has run with no issues since then until today. What is the problem now?
Any thoughts are appreciated
John
Old Feb 22, 2014 | 04:35 PM
Rimrock F1's Avatar
Rimrock F1
If it does not start on starter fluid the only things I can think of is. It is flooded, hold throttle wide open and crank to clear. It has weak or no spark on multiple cylinders or is timed off ( unlikely if you have not changed anything since last run). Has low or no compression ( also unlikely since it ran fine before). So if it were mine I would try clearing a flooded condition first, happened to our 52 today. If that didn't work I would check for strong spark on all cylinders.
Old Feb 22, 2014 | 05:09 PM
bobj49f2's Avatar
bobj49f2
Sounds like my F-2 last year. It ran fine most of the summer but I got busy at work and didn't drive it for over a month. When I tried.to get it to start it just spun over. It would try to kick but just couldn't. I.checked.everything I could think of. A couple of fellow FTErs stopped over and we checked compression. Low in all cylinders. We pulled started it, started within 25 feet and ran great the rest of the year. The rings must have contracted but once they warmed up they expanded.
Old Feb 22, 2014 | 05:14 PM
f5fordgirl's Avatar
f5fordgirl
You might try pulling the plugs and putting a little oil in each cyl to bring compression up.
Old Feb 22, 2014 | 05:54 PM
drptop70ss's Avatar
drptop70ss
Sounds like either the fuel is crap or the carb needle is stuck closed. The engine is not going to run on starter fluid unless you keep spraying it into the carb while it is running, are you doing that or just giving it a single spray? The fact that it fires with the starter fluid it sounds to me like you are missing fuel from the equation.
Old Feb 22, 2014 | 06:09 PM
Giesterfarher™'s Avatar
Giesterfarher™
Try carefully filling the carb bowl with gas through the vent. Wipe up any spillage before you try cranking it over. If it starts and runs then, but runs out of gas, you most likely have either a stuck needle, or the fuel pump gave out, probably tore the diaphragm when you were cranking it over.
Old Feb 22, 2014 | 07:33 PM
carnut122's Avatar
carnut122
That's my take on it too!^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old Feb 23, 2014 | 12:25 PM
petemcl's Avatar
petemcl
The previous suggestions are all good. But if you stored your truck in an unheated location you may have some ice in the fuel bowl or in the glass bowl on the bottom of the fuel pump. If it was in a heated location the try a little ether sprayed down the throat of the carb. Most tractor dealers sell small spray cans. Just don't use too much.
Let us know how that works. Lots of experience on this forum starting old flatheads.
EDIT: Ahhh . . . I see you are in Atlanta. I think that you have had enough warm weather lately that ice should not be the issue. I would try the ether.
Old Feb 23, 2014 | 02:55 PM
arctic y block's Avatar
arctic y block
I am with Bobj on this one. Try to pull start her.
Old Feb 23, 2014 | 03:39 PM
obscurity's Avatar
obscurity
So it finally started but I still don't know why it was so hard. I got fed up and this morning decided to go to the local autozone to get some new plugs and plug wires and a new can of ether (mine was getting a little light.) Of course autozone had no plugs for the truck (I tried to get the champions but they were out of NGK and autolite as well) and had no plug wires. Apparently all they carry is air freshener and chrome do-dads for late model cars. So I took the starting fluid home and it started but reluctantly. This morning it was much easier to start.
I would live to find a guy/shop in Atlanta who could give me an assessment to the state of the engine and tune it up.
Thanks for all the pointers
Old Feb 23, 2014 | 03:47 PM
oldmerc's Avatar
oldmerc
oldmerc
Just for fun do a compression test and post the results
Old Feb 23, 2014 | 03:50 PM
bobj49f2's Avatar
bobj49f2
I would guess by loading it with starting fluid you might have gotten it warm enough for the rings to expand enough to bring the compression up to start. Also, the starting fluid probably produced a strong enough burst to spin the engine a little faster to over come the low compression. Although, I could be totally wrong.
Old Feb 23, 2014 | 04:20 PM
Giesterfarher™
Sounds like it was flooded after all. Next time you start it, try cranking it without pumping the pedal or setting the choke and see what it does, then add choke a little at a time while cranking as needed.
84XLF150
Nov 25, 2015 02:16 PM
collinrandle
16
Nov 17, 2015 01:13 AM
llangbehn
18
Mar 1, 2013 10:21 AM
Aaronman
38
Sep 30, 2012 02:13 PM
justforkicks
Dec 10, 2011 04:05 AM
