high idle
Old Apr 18, 2021 | 02:57 PM
dremtofford's Avatar
dremtofford
high idle
i probably have a thread on this but i cannot find it. the truck fires right up then jumps to 3000 rpm according to the tach. i have cleaned the throttle body, changed the coolant temp sensor, disconnected the spout and that brought it down to 2500, it runs smooth and fires right up. i sprayed carb cleaner around the base of the intake, no change, u even unplugged the idle control, no change. it revs up fine, i know it probably has a blown head gasket by all the white smoke and the pressure in the radiator after 1 minute. would that cause a high idle?
Old Apr 18, 2021 | 03:17 PM
Mudsport96's Avatar
Mudsport96
Head gasket issue shouldnt cause an idke issue. What year and transmission? I know its most likely the e4od, but if its a c6 the vacuum modulator may be bad and atf burns white.
Also, pull and plug the brake booster hose to rule out a vacuum leak there.
Old Apr 18, 2021 | 09:12 PM
dremtofford
it is an 88 with a 302 efi and a 5 spd manual 4x4. i only paid 100 bucks for it to get it out of his yard.
Old Apr 18, 2021 | 10:49 PM
Mudsport96's Avatar
Mudsport96
Thats a deal. Well unplug and cap off the brake booster hose for starters and see if that helps.
Old Apr 19, 2021 | 09:26 PM
dremtofford
i will try that next time.
Old Apr 20, 2021 | 05:47 AM
phoneman91's Avatar
phoneman91
The gasket between the upper and lower intake manifold can cause a high idle if defective and letting air bypass the IAC. Also disconnect the electric leads to the IAC and see if the idle changes.
Old Apr 21, 2021 | 09:24 AM
dremtofford
i tried disconnecting the leads on the idle control not a whit of change. i have a blown head gasket, i hope, so i need to change a few gaskets
Old Apr 21, 2021 | 10:38 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m fairly certain that when you replace the intake manifold gaskets in the process of replacing the head gaskets is when you will fix the vacuum leak.
Old Apr 21, 2021 | 11:23 AM
phoneman91's Avatar
phoneman91
Never mind--I just noticed that you have white smoke.
Old Aug 26, 2022 | 08:29 PM
dremtofford
found part of the problem. four of the lower intake bolts were tight the rest were just sitting there covered with grease and oil. the rest of the bolts on the engine were not very tight. i took them off with a 3/8 ratchet. drivers side had blown gasket and no.5 exhaust was burnt. got that head fixed for 50 bucks now on to the passenger side.
Old Aug 27, 2022 | 07:28 AM
My4Fordtrucks
You have so many threads about this engine problem and disassembly that’s it’s hard to keep track.
45FMJoe
Dec 2, 2017 06:36 AM
twinarrow99
1983 - 2012 Ranger & B-Series
Sep 12, 2006 09:30 PM
chuck641
May 13, 2003 10:50 PM
markcaillier
Sep 1, 2002 03:50 PM
roadrunnerman74
Jun 1, 2002 09:59 PM
