Radio Sync question
I started poking around the different menus and under automatic updates found its downloading update. Ok no problem I will just give it
some time. Well its been a week and the progress bar has not advanced past the 50% or so it was at when I found it. I am not sure
what the update is or what I can do to get it to finish or just clear it out. I tried getting the truck on my wifi and left it sit 15 min running
while on wifi with no change. Connected my phone and spent a couple hours on road no change. After looking it seems I have the
current Sync 3.4 build 20136. I have not tried any updates or loading any software via USB or anything its as it was when I got truck.
This is the file name it shows its working on.
4U5T-14G422-CAF_1580862253000.TAR.GZ
To do a soft reset: Hold down the Power button and the Right Seek button for at least 5 seconds. If that doesn't work you can try putting it in Diagnostics Mode: Hold down the Eject button and the Right Seek button for 10 seconds.
If that doesn't work, unhook your battery cables for a few minutes (you will lose your settings).
