Sync 3 Defaults to radio on startup
I have noticed within the last week or so when I start my truck Sync has defaulted to the radio input. 99% of the time I am listening to Sirius vs over the air.
Each time I start my truck I have to change the input. It has been a couple weeks since I did the last Sync 3 update and this behavior was not happening after that. I have not done a reset yet but I may do that soon.
Has anyone else run into this issue?
I guess i`m in the minority or just lucky because after I did the 3.0 update, whenever I start up my vehicle, the SYNC 3 system always reverts back to whatever I was using the last time I turned my vehicle off and it`s been this way starting with version 1.0 to the current 3.0
2016 F150 here.
2016 F150 here.
I called Ford, and the rep said that the FM default is the way they've designed it and is not a issue as far as they are concerned. If you don't like it, people need to complain to Ford to get it changed. The # for the "In Vehicle Technology Team" is 800-392-3673 and then the prompts to get you past the voice menu are 1 for English (this one always pisses me off), 3 for Sync, 1 for Sync again and 2 for other. You can press them as soon as you start to hear the options so it doesn't take long.
