ts 6 position chip not working
Old Apr 15, 2021 | 04:23 PM
ballbandit's Avatar
ballbandit
got a 01 7.3. chip works on high idle. no power gains on any levels. sent chip back. they said it's good. I've installed several chips so pcm is clean. I even switched pcm with another one of same code. still no difference. tried another chip and switch also. I'm lost. truck runs fine just chip isn't doing anything. has 135k miles on it. any ideas? thanks
Old Apr 15, 2021 | 04:52 PM
Colorado350's Avatar
Colorado350
Who did you send the chip to? And when they said it’s good did they say that it actually had tunes on it or that it’s capable of holding Tunes?
Old Apr 15, 2021 | 07:45 PM
ballbandit's Avatar
ballbandit
ts. and said it's good. I even got another chip for same pcm. same issue
Old Apr 15, 2021 | 08:11 PM
Colorado350
@cleatus12r Cody may some insight for you.
Old Apr 16, 2021 | 03:48 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Is the CEL lit? Got any codes?
Old Apr 16, 2021 | 04:47 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Just to make sure we are clear, high idle works, but none of the other positions change the tuning of the PCM?
Strange if so, but we are determined to help you out. Keep talking to us...
Old Apr 16, 2021 | 05:26 AM
ballbandit's Avatar
ballbandit
no light only code was kam
Old Apr 16, 2021 | 05:27 AM
ballbandit's Avatar
ballbandit
yes that's correct. definitely something crazy
Old Aug 24, 2021 | 08:44 AM
ballbandit's Avatar
ballbandit
update
so now I've tried 3 pcms. still same just high idle. one pcm was used but never had chip on it had to clean it. another one was a reman one. I even switched idm. no help. I put a pcm out of an automatic and a ts chip and truck responds to settings. I put original one back in removed chip and downloaded a program. truck responds. so as of now guy is driving it with programmer on it. truck has had chip on it for years just one day it started acting funny
Old Aug 24, 2021 | 11:49 AM
Sous's Avatar
Sous
FTE Emeritus
Still strange, but it is not unheard of for electronics or electrical devices to have a mind of their own at times. I used to say they were worse than a teenager because at least a teenager is capable of feeling remorse.
There is one common failure point or part I see in your posts.
papadelogan
Ford Truck Parts for Sale
Jan 5, 2010 08:13 AM
raptor05
May 17, 2006 09:36 PM
polar88
Computer Chips & Tuners
Mar 7, 2005 01:11 PM
RustyWallace
Nov 16, 2003 11:24 AM
Trail Rider II
Sep 14, 2003 10:55 AM
