Sponsored by: Real Truck
overfull Transfer case
Old Apr 11, 2021 | 02:35 PM
B931070me's Avatar
B931070me
Angry overfull Transfer case
97 Ford F-250 HD 460, 4x4
Kept putting trans fluid in my 4AOD trans. Found the transfer case to be overfull.
Can I assume there is a seal between the trans and transfer case that is bad?
Thanks,
Old Apr 11, 2021 | 02:52 PM
WWR's Avatar
WWR
Yeah, I've never fully understood this because the tailshaft housing should only have a little fluid in there and the t-case input seal is pretty high relatively but supposedly your situation is not uncommon.
I had a friend who experienced it years ago and Makuloco specifically addresses it, albeit on '04-08 F150s, go to 31:30
Old Apr 11, 2021 | 05:10 PM
SuperDutyScaler's Avatar
SuperDutyScaler
Yes the seals are no good between the trans and t-case. The trans pump circulates the fluid and the return line goes right into the tail section to lube the bearings. So yes there is pressure while it's running and when the seals go bad it pushes the fluid right past it and into the t-case.
IMMEDIATELY fix this by the way
Old Apr 12, 2021 | 02:52 PM
B931070me's Avatar
B931070me
Got it out, Thanks, I see a large seal on the input shaft of the transfer case. Is that the seal that needs replacing? Does it come out the front of the transfer case?
Thanks,
01FordEx
Mar 17, 2016 09:47 PM
ChrisMelton78
37
Mar 20, 2014 05:09 PM
duvaltom
Jan 1, 2013 08:51 AM
bulletpruf
Sep 18, 2011 10:54 AM
47studebaker
Jun 23, 2007 01:47 PM
