Injectors?
Old Apr 11, 2021 | 01:49 PM
huntinfishn's Avatar
huntinfishn
Injectors?
About 5 weeks ago i thought i was noticing a slight miss. Changed the Ficm board and harness. 2 weeks ago i went on a fishing trip t pulling my bass boat, and my truck started missing noticably when running 55-62ish. Babied it for the week and limped it home. Got home and replaced both fuel filters, fuel pump, o-rings and blue spring in the regulator. Still missing. Run the buzz test on AE, #7 fails when cold but not hot. Having problems with the AE turning off the cylinders, working with them to try and fix it. I did manage to shut off six of them, but could not shut off 2 & 8. Today, I installed a fuel pressure gauge and the pressure runs 75+ and at WOT uphill only dropped to 70psi. With 212k miles, I am thinking it might be time to just go ahead and replace the injectors. Does anyone have any insight on what it might be besides injectors?
Appreciate the help, thankful for this site.
Old Apr 11, 2021 | 02:04 PM
bismic's Avatar
bismic
What brand FICM was installed (also - complete new FICM or just a Power Board)?
Old Apr 11, 2021 | 03:35 PM
huntinfishn
Tech smart, just the board.
Bismic, i went back and edited the timeframe, i was noticing a slight miss before changing the Ficm board, it got worse on the trip. Sorry for the confusion.
Old Apr 11, 2021 | 04:01 PM
bismic's Avatar
bismic
Only reason I asked was because sometimes it is the Logic Board that isn't working correctly.
Old Apr 11, 2021 | 04:46 PM
huntinfishn
Ok, i will do some research on it, thanks.
Old Apr 11, 2021 | 05:49 PM
huntinfishn
I guess the best way to test this is with a known good ficm?
Old Apr 11, 2021 | 06:42 PM
tfunk88's Avatar
tfunk88
I know this is off topic but what fuel system do you have for 75psi?
Old Apr 11, 2021 | 06:50 PM
huntinfishn
Racor with blue spring, does it seem high? The gauge is a new glowshift. At idle it sets at 78.
Old Apr 11, 2021 | 07:20 PM
Brotherbillstruck's Avatar
Brotherbillstruck
I have the stock fuel system and blue spring also and runs 72- 75 at idle. I know it's higher than what I see folks report here. I also have the glow shift gauge and now I wonder if it reports correctly.
Old Apr 11, 2021 | 07:27 PM
bismic's Avatar
bismic
yes .
Old Apr 11, 2021 | 09:01 PM
tfunk88's Avatar
tfunk88
Man, mine is at 60-62 at idle and drops to 45 at wide open throttle. I have the maxtow gauge, which I think is also glowshift
Old Apr 17, 2021 | 02:09 PM
huntinfishn
Could the logic board cause an injector to go bad? I just replaced all eight injectors, ran fine idling for about an hour. I went to drive it, and it started stumbling. Checked the codes and got a 7 contribution code. Sure enough, it failed the buzz test. Swapped the harness connectors around and number 7 plug will buzz number five injector. Number 5 plug would not buzz number 7 injector. Wondering if the logic board or power board could kill an injector that quick or did i just get a bad injector.
Old Apr 17, 2021 | 03:28 PM
bismic's Avatar
bismic
I haven't heard of that happening. Whose injectors did you install? I have heard of aftermarket remanned injectors failing that quickly.
Old Apr 17, 2021 | 03:39 PM
namnguye's Avatar
namnguye
If number 5 injector now buzz, may mean it's still good.
So maybe just the FICM flailed?
Old Apr 17, 2021 | 03:54 PM
bismic's Avatar
bismic
The way I read it (after a couple of re-reads, lol):
#5 connector buzzes #5 injector
#7 connector does not buzz #7 injector
#7 connector buzzes #5 injector
#5 connector does not buzz #7 injector
