Speedometer cable re install
Old Apr 10, 2021 | 07:55 PM
MB1776's Avatar
MB1776
1977 f150 4x4 c6 np205
Speedometer cable originally was bouncing around, going all the way to 80 and not return while driving or just back and fourth .
The mechanic bought a brand new speedometer cable, it was installed into a rebuilt transmission/transfer case by the shop while that was being done. The problem remained with the sporadic cable so I took the cable out of the dash , installed a new speedometer gauge off eBay and currently trying to get the cable back into the gauge .
Got it barely inserted but it is easily pulled out if you tug on it even after attaching the white clip. Also the sporadic gauge problem remains. It is very loud you can here the cable turning behind the gauge, sounds like metal bearings rotating to best describe the sound. I even greased up the cable on the inside.
How the heck do I re install this cable correctly and make the gauge work properly again ?
thanks !
Old Apr 11, 2021 | 12:50 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I bet your speedo "head" assembly is bad as a far as the not working and noise problem.
Old Apr 11, 2021 | 01:59 AM
meangreen92's Avatar
meangreen92
Maybe unbolt and pull the cable out of the transmission, and try turning it as you attempt to get it engaged with the 'chuck' in the distributor.
The speedometers I've seen from inside had the cable driving a piece with two arms sticking out, with magnets on them. Those magnets fly around a metal disk which is directly connected to the needle. There is a delicate copper spring which acts to pull the metal disk and needle to 0 MPH when the magnets aren't orbiting/flying around the metal disk.
The flying magnets act against that spring tension to make the needle indicate whatever speed.
If the bushings are worn out, the assembly will get sloppy enough to where the flying magnets are hitting the metal disk, which causes the needle to jump up abruptly. Sometimes a smoother cable will get rid of that problem, but if a choppy cable is used for long enough of a time, it will wear out those bushings in the speedometer head.
Old May 11, 2023 | 08:45 PM
ksample1985's Avatar
ksample1985
Speedo
Sounds like speedo cable, as far as rebuilding you can do it yourself take your time and should have no problems, I would get you a donor speedo from salvage yard and install, you can reset the odometer to match miles as well
gostephen
Mar 1, 2018 07:39 PM
FordIowan
Dec 11, 2012 08:46 PM
brucewon
Mar 23, 2010 08:07 PM
baddmove
Bronco II
Feb 17, 2009 11:33 AM
WhiteBroncoII2WD
Bronco II
Oct 24, 2008 11:20 AM
