Truck Height??
Old Apr 12, 2021 | 10:39 AM
james_1988f250's Avatar
james_1988f250
It does appear to have a lift-kit based on the gap between the tires and the fenders probably 4 inches. You can tell if there are blocks under the leaf springs between the axle and the spring. Also those tires are bigger than factory and would raise the truck a bit as well.
Old Apr 12, 2021 | 10:41 AM
james_1988f250
Beautiful truck.
Old Apr 12, 2021 | 10:44 AM
james_1988f250
That's just based on the pictures I can see but this truck could have come with a higher stock height.
Old Apr 12, 2021 | 01:59 PM
scottishteacher's Avatar
scottishteacher
Thank You!!
Thank You so much for your time!! I will take a look underneath to see if there are blocks present!
Old Apr 13, 2021 | 02:24 PM
mrollings53's Avatar
mrollings53
Doesn't stock 4x4 have blocks on the back axle? Otherwise the rear end would be squatting. Lift kits just change the height of the blocks.
Old Apr 13, 2021 | 02:30 PM
james_1988f250
Yes, but usually they add blocks so there would be more than one block per spring. You can also tell if the front leaf springs are a Ford part or not look for the emblem or labeling.
Old Apr 13, 2021 | 02:56 PM
scottishteacher
Thank you all
I looked and there are blocks with the leaf springs and they are Ford parts so it’s probably just a tall truck. Thanks to everyone that replied I appreciate you all
BrownBob
Jun 28, 2019 11:17 AM
mbovinet
Mar 1, 2018 05:54 PM
jaygee15
2015 - 2020 F150
Jan 5, 2018 12:38 PM
samurai
Jul 24, 2008 09:36 PM
Jeremy2792
Jun 11, 2008 03:23 PM
