Plenum leak
Old Apr 9, 2021 | 07:14 PM
lpzd's Avatar
lpzd
Plenum leak
I'm not very good at detailed threads on what's being done to my truck, but I made a comment in another thread about some low buck plenums I found online. They showed up quick layed flat and the bolt holes all lined up, for under $100 I'm not sure I could have expected any better.
Old Apr 9, 2021 | 07:57 PM
sjbj's Avatar
sjbj
Which ones are those? I was debating on some Chinese ones from eBay or Amazon that are cheap in price, but I decided to hold off this round.
Old Apr 9, 2021 | 10:42 PM
lpzd's Avatar
lpzd
Cheap ebay ones
Old Apr 9, 2021 | 10:46 PM
sjbj's Avatar
sjbj
Originally Posted by lpzd
Cheap ebay ones
impression on quality? Which seller?
Old Apr 10, 2021 | 07:58 AM
lpzd's Avatar
lpzd
Seller was siliconehosehome quality was better than expected, welds look good no issues with install end hole was notched and milled down to still use the front passenger side bolt.There are several vendors selling the same units .
I'll finish putting evening else back on today and update when it's completed.
Old Apr 10, 2021 | 10:15 AM
sjbj's Avatar
sjbj
Thanks for the info. With my recent project I was seriously considering picking up some of these plenums, but I couldn't find much feedback on the Chinese versions. Irate's version are close to $250 and Riffraff's are $300+. Didn't have the coin for that, but was scared to be the guinnea pig on a set of Chinese for less than $100. Perhaps if timing was right and I saw your post I might have gone your route. I don't think mine are leaking, but I don't know for sure. If I find they are I'll look forward to your continued feedback on these....
From the pictures they look nice.....
Old Apr 10, 2021 | 02:55 PM
F350towing's Avatar
F350towing
Just curious about the mating surface side of them.
Was there a groove similar to the stock plenums to act as a retention pocket for the TA 31 sealant?
They seem easy enough to make out of some flat stock aluminum and pipe.
Old Apr 10, 2021 | 03:57 PM
lpzd's Avatar
lpzd
Mating surface is flat, I thought about making some but for the price I couldn't justify my time investment to make a set.
Pressure tested no leaks, new fuel line seals went ahead and through on a deatschwerks pump to keep up with fuel demand. Done with the truck, till next time.
Are they billet and beautiful NO but you can't see them any way.
Old Apr 10, 2021 | 04:30 PM
sjbj's Avatar
sjbj
They look nice. If I end up getting a leak, I may go the route you did for cost. But mine will get powder coated....lol Thanks for the feedback on these....
Old Apr 10, 2021 | 06:45 PM
lpzd's Avatar
lpzd
I was little hesitant to post pick of mine after seeing yours.
Old Apr 10, 2021 | 06:56 PM
ESwift's Avatar
ESwift
CNCFAB
If you move enough and get rid of some stuff, you can see em a little bit
Old Apr 10, 2021 | 11:14 PM
sjbj's Avatar
sjbj
Boy, if you remove the fuel bowl and the relays it really opens that area up? Am I missing something else? Where did you put the relays?
Old Apr 11, 2021 | 05:29 AM
ESwift's Avatar
ESwift
CNCFAB
Gpr on fender, no aih as it is e99
Bohen
6.7L Power Stroke Diesel
61
Jul 23, 2020 07:28 AM
honeydew
Oct 13, 2012 12:48 PM
scottf4444
Dec 27, 2009 11:05 PM
Ranger88Den
Jun 29, 2005 09:45 PM
Rocking M
Dec 29, 2003 09:51 PM
