Upfitter question
Old Apr 8, 2021 | 09:45 PM
Buckwuk's Avatar
Buckwuk
Upfitter question
For installing things on the upfitters that require a smaller fuse than what is currently on the upfitters, can you simply just replace the 25 amp fuse with a 15 amp? Or do you just add an inline fuse after the connection to the upfitter?
Old Apr 8, 2021 | 10:56 PM
MagicMtnDan's Avatar
MagicMtnDan
Neither; the fuse isn’t an issue when drawing lower amperage power
Old Apr 8, 2021 | 11:34 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Sure it is, you still have to protect whatever component you hook up to the upfitter switch.
So, yes, I would definitely just add an inline fuse of whatever capacity required to protect the component you add.
Old Apr 8, 2021 | 11:39 PM
Chad149's Avatar
Chad149
That won't be a problem, go right ahead and swap the factory fuse.
If the op is installing an accessorie that risks a "thermal incident" if the full rated amperage of the upfitter go thru it, either the fuse needs to be changed or a second fuse of appropriate amperage needs to be installed. The fuse Ford puts on the upfitter is what they designed the circuit to handle, but no reason it can't be lower, since they have nothing on said circuit.
Old Apr 9, 2021 | 06:27 AM
BillyE's Avatar
BillyE
I’d change the factory fuse to the lower rating. Would be cleaner than a second fuse.
Old Apr 9, 2021 | 11:41 AM
2019er's Avatar
2019er
and change the marking, to clear up confusion later if it needs to be changed? Or would it be cleaner to install a smaller rated fuse inline between the device?
Old Apr 9, 2021 | 12:36 PM
2020STX250's Avatar
2020STX250
It won't hurt a thing to drop fuse sizes to match the connected load, its actually a pretty good idea to do so. It could possibly help prevent an overload from becoming a fire.
Old Apr 9, 2021 | 04:15 PM
BillyE's Avatar
BillyE
Originally Posted by 2019er;[url=tel:19823522
19823522[/url]]and change the marking, to clear up confusion later if it needs to be changed? Or would it be cleaner to install a smaller rated fuse inline between the device?
it really doesn’t matter. It’s up to you. Both work. I’d prefer to not have an inline fuse holder.
Old Apr 9, 2021 | 04:22 PM
TB250's Avatar
TB250
In-line fuse holder is two more splices and something to forget about later when something happens. Replace the upfitter fuse with the correct size for what you installed.
Old Apr 9, 2021 | 05:10 PM
Buckwuk's Avatar
Buckwuk
Thanks for all the recommendations, I think I'll just change the fuse in the upfitter box.
Old Apr 9, 2021 | 08:20 PM
stephen.osborne1's Avatar
stephen.osborne1
How many amps should these accessories draw?
Old Apr 9, 2021 | 08:45 PM
Chad149's Avatar
Chad149
Wife mute is gonna be a problem. That will need to power off the PTO.....
Old Apr 9, 2021 | 09:47 PM
stryder's Avatar
stryder
The PTO is nowhere near enough. He'll probably need to install a Mr Fusion reactor for the necessary 1.21 gigawatts.
Old Apr 9, 2021 | 09:51 PM
stephen.osborne1
You've met my wife?
Rusty_S
Electrical Systems/Wiring
Feb 20, 2014 08:36 PM
emaksb
Aug 11, 2011 11:22 AM
JoeVB
Jun 3, 2007 12:06 PM
trvaughn
Oct 24, 2005 07:01 PM
conchsally
Jul 3, 2004 06:53 AM
