Breaker vs. Fuse
Old Jun 2, 2007 | 11:03 AM
JoeVB's Avatar
JoeVB
Breaker vs. Fuse
I have an AMP for my stereo in my truck and it uses a 40A fuse to get its power from the battery. I have never blown this fuse.
I want to know if I can replace this with a 40A breaker? The problem with the fuse is that the connections aren't that good because no connectors are made for it so I need to make them and often the AMP will lose its power.
I don't see a difference between a fuse and a circuit breaker but I am not 100% sure, that's why I am asking.
Thanks
Old Jun 2, 2007 | 11:20 AM
ncguy23's Avatar
ncguy23
Its my understanding that a fuse protects one time only and must be replaced, while a circuit breaker can be manually reset and used again.
Is the fuse blade style or cylindrical?
Old Jun 2, 2007 | 11:25 AM
JoeVB's Avatar
JoeVB
blade style
Old Jun 2, 2007 | 02:08 PM
ncguy23's Avatar
ncguy23
Id say keep going with the fuse and figure out better connectors, personally I don't think the breaker would work out.
http://www.sherco-auto.com/electacc.htm might find something there connector wise
otherwise, id say keep searching google, there has to be something out there
someone else probably knows more about this than me
Old Jun 2, 2007 | 07:33 PM
EMoeFord's Avatar
EMoeFord
I'm getting ready to upgrade the stereo in my 94 Ford, which will require an 80 amp fuse under the hood. I'm going with the fuse holder & fuse; #1 because it's cheaper, #2 it's easy to trouble shoot for failure. A breaker's mechanics (internal parts) will most likely fail over some time (may take years though), which mean replacing the entire thing, where as a fuse holder, which only requires changing the fuse; much faster & cheaper process.
If you can't repair what you have, I'd buy a new fuse holder. The only advantage to the breaker, is that "it's more up to date in car audio", and it looks better (but it's out of view, under the hood).
Really what it all boils down to is personal preference!
Regards,
EMoe
Old Jun 3, 2007 | 12:06 PM
mhg's Avatar
mhg
stick with your fuse system and locate a dealer for proper connectors
the breaker systems are designed to operate must have systems
and will continually reset and operate the system even with a dead short
the headlamps are a perfect example. you can get to a safe place to stop
without total loss of the system
putting that large of a breaker in your system that will continually
reset and send several HUNDRED AMPS down that wire to a dead short
even for only a split second but over and over will start a FIRE
nuf said. mike
