HELP PLZ
Old Apr 8, 2021 | 05:48 PM
powerstrokeN1's Avatar
powerstrokeN1
Trailering
HELP PLZ
RE: Hello Everyone HELP PLZ
NO START
What causes ipr 65% and icp 2400/2600psi while cranking?
99 f350 New IDM,fuel filter,icp,ipr,uvhc and pigtails,glow plugs,GPR,high torque starter. Engine and hpop oil level is great
I do get white smaoke when cranking. Truck sat for 3 years so I am using 5 gallon can with diesel with a temporary fuel line hooked straight to pump under the driver door. Have notmhad a chance to drop and clean the tank yet. The truck started for about 30sec. first turn over. It ran rough which I expected but I cannot get it to start back up.
Old Apr 8, 2021 | 06:00 PM
FordTruckNoob's Avatar
FordTruckNoob
Start with this.
Old Apr 8, 2021 | 07:33 PM
Colorado350's Avatar
Colorado350
Welcome to the Forum
Are you using OEM Sensors? They trucks don’t like aftermarket sensors or glow plugs. Keep the charger on your batteries during attempts to start your truck. Leonard has you pointed in the right direction.
Old Apr 8, 2021 | 07:52 PM
powerstrokeN1
Trailering
I am using OEM sensors and they were expensive. I'm not sure if the gp are OEM. They came with he truck. I am getting P0605 p0475 P1118. I bought the truck and I drove it for a year or so then 1 day it went into limp mode. I got it towed home and started to work on it. Eventually buying AE and was pretty sure it needed and Idm after replacing everything. I finally bought an Idm in January of this year and started to work on the truck again. Boom finally got injectors to buzz and we were are where we are now. It's getting frustrating to say the least. I dont think it's the pcm. Getting all the signal wts light etc. That makes me believe it's good. I did check the gpr this past weekend and it seems.to be working properly. I dont have a way to test fuel pressure but I'm getting a full bowl, white smoke, and the diesel is disappearing out of the can.
Old Apr 8, 2021 | 08:02 PM
Colorado350
Is your fuel ball heater plugged in? If it is unplug it and double check your fuse. Do you know what your codes are for or do you need a link for those? Since it’s been a while, and you did get it to start hopefully it’s something simple like just air in the lines.
Old Apr 8, 2021 | 08:06 PM
AllaboutMPG's Avatar
AllaboutMPG
There is an easy method to check fuel pressure with some hose and an inexpensive 0-100 gauge. Hook the hose to the fuel bowl drain. If pressure regulator is bad fuel could just be going into the tank through the return line.
65% ipr is high. Pcm is asking for more pressure. You said 2600 psi so not sure what's going on. Maybe time for an hpop dead head test.
Old Apr 8, 2021 | 08:07 PM
powerstrokeN1
Trailering
Fuel bowl heater is unplugged. I actually removed the heater but I left the plate in the bowl. Fuse is still good.
I'm extremely confused on how icp 2400/2600psi when cranking and icp DC starts at the normal 14.4% but when cranking is maxed out.
Old Apr 8, 2021 | 08:08 PM
powerstrokeN1
Trailering
Could glow plugs cause that?
Old Apr 8, 2021 | 08:09 PM
AllaboutMPG
what are the air temps where you are
Old Apr 8, 2021 | 08:11 PM
powerstrokeN1
Trailering
Not sure how to test the hpop. What do I need tools/ supplies to do so?
Old Apr 8, 2021 | 08:12 PM
powerstrokeN1
Trailering
Air temps were 70-80 degrees this past weekend when trying.
Old Apr 8, 2021 | 08:28 PM
AllaboutMPG
You will need an ipr blocking plug, a dead headed hpop hose and a hpop hose with adapter with 0-3000 psi guage to test the hpop. Riff raff has the Ipr blocking plug. I took an old set of hpop hoses to a local hyd shop and had them cut off one end and add jic fittings to cap one off and adapt the other to the guage.
70-80 degrees you should not need glow plugs so probably not your issue
Old Apr 8, 2021 | 08:32 PM
AllaboutMPG
I would also look at the wires to your icp. The default pressure the pcm uses when icp is unplugged is about 2600 iirc. If you have a bad wire the pcm may not be seeing icp.
Old Apr 8, 2021 | 08:36 PM
powerstrokeN1
Trailering
I looked at the wires in the loom about 6-8" down and dont see any skint wires. Is it possible the actual plug on the pigtail is bad. How would i test just the plug unhooked from the icp? Check to see if it's getting voltage or what?
Old Apr 8, 2021 | 08:42 PM
BWST's Avatar
BWST
Got Data?
NO START
Try unplugging the ICP and see if it will start. Just to rule out a defective ICP sensor.
If it still does not start, we'll assume ICP is good, and IPR is climbing because we're not getting fuel. As has been suggested, see if you can get a fuel pressure measurement.
Does the truck have a chip? P0605 might just be from the performance chip.
What does FIPW (AE) or FUELPW (FORScan) read when cranking? Should be at least 0.6ms if PCM/IDM are in sync.
What is your cranking RPM and cranking voltage?
