Overheating 6.0
Old Apr 9, 2021 | 01:57 PM
FiveOJester's Avatar
FiveOJester
Originally Posted by StopTheThreat52
I filled the system with water and found a leak at the seam on the top of the radiator.....so I know first step is to replace the radiator (any suggestions on brand?) .... had an extra degas cap that threaded on just fine....would a crack in the radiator cause the system to pressurize that much to warp the degas cap or would something else cause the pressure and that broke the radiator and degas cap?
From everything I've read all the aftermarket radiators have less fins/inch that the stock and thus offer decreased cooling capacity. Even the expensive Mishimotos. I push my cooling system to the limits all summer towing in 100F heat so I went with a stock replacement on my previous truck. Had to buy thru a local dealer as UPS destroys them.
If you aren't towing heavy in high heat the aftermarkets should be fine. Performance Radiator is a good option. They apparently supply the unit that Bulletproof Diesel sells for about 2x the price.
birdrv
Modular V10 (6.8l)
Oct 14, 2020 12:08 PM
HunerdProof1371
Sep 1, 2015 05:19 PM
f3fidy
Mar 20, 2011 09:48 PM
Cephus
Aerostar
Jul 3, 2005 05:42 PM
srmn8r
Aug 10, 2003 05:44 PM
