Harness needed BAD
Old Apr 6, 2021 | 07:24 AM
joseph_bishop's Avatar
joseph_bishop
Harness needed BAD
Got a 2001 f250 7.3L 4wd automatic transmission and automatic transfer case
front drive shaft broke and took out the harness for transmission and transfer case and the harness running to the rear for lights etc
this is like trying to find a needle in a haystack so anyone that could help locate this would really be great
Old Apr 6, 2021 | 07:29 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
In the short term, can you splice the wires back together until you find a suitable replacement? Harnesses are out there, just have to be specific with what you are looking for, they are pricey though.
Old Apr 6, 2021 | 07:46 AM
joseph_bishop
thanks Sous
Old Apr 6, 2021 | 02:36 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Try Spalding 509-924-3300
Old Apr 6, 2021 | 06:52 PM
Colorado350's Avatar
Colorado350
@joseph_bishop
Verify it yourself but I think this what you need:
https://www.ebay.com/itm/324010825169
Other options...
https://www.ebay.com/itm/333822300548
or
https://www.ebay.com/itm/233950681041
Old Apr 6, 2021 | 08:30 PM
2001F350dualwheel's Avatar
2001F350dualwheel
I have one off a V10 4x4 I parted out. Guy only wanted the frame so that what I gave him. I stripped everything off the frame. Literally everything. I also have the brake lines if needed. I bet the only difference is the connector for the fuel pump. This is the MAIN rear harness from under hood main connector to the back of the truck running along the driver side frame rail with the branch off for the trans and transfer case all the way back to the tail lights and hitch 7 pin connector right? Are you local in So Cal? You can swing by and check it out if you want. I can send you some pics if you pm me a phone number
Old Apr 6, 2021 | 09:45 PM
joseph_bishop
Originally Posted by Colorado350
Thanks a million!
The third link was a charm
Old Apr 6, 2021 | 09:46 PM
joseph_bishop
Thanks a million!
Third link was a charm
Old Apr 6, 2021 | 09:47 PM
joseph_bishop
Thank you but found one elsewhere
Old Apr 6, 2021 | 09:50 PM
joseph_bishop
Thanks Bitterroot
Old Apr 7, 2021 | 12:00 PM
Colorado350
Thanks a million!
Glad you found what you need!
Old Apr 7, 2021 | 02:54 PM
joseph_bishop
2001 harness needed badly
I have a 2001 f250 super duty 7.3l automatic trans and automatic transfer case.
Thanks to replies i was able to locate the trans and transfer case harness.
However when the front driveshaft broke it also damaged the harness running down the left frame rail which goes towards fuel tank and rear lights, it also powers up the frame mounted fuel pump. Really need badly and willing to pay for correct part.
Please advise if you know where this may be. the part number is 1C3Z-14405-EA but is obsolete.
Old Apr 7, 2021 | 07:19 PM
uglypitbull's Avatar
uglypitbull
You sure its a 1 and not a 7?
https://www.fordpartsgiant.com/parts...-14405-ea.html
Tbrooks26
Aug 31, 2017 08:42 AM
JClark785
Nov 13, 2016 07:52 PM
GIO23
Aug 23, 2009 05:57 AM
jason85351
Sep 9, 2008 10:30 PM
