Steering Components
Old Apr 5, 2021 | 06:19 PM
BleedMichigan's Avatar
BleedMichigan
Steering Components
So I have a RWD not 4 wheel drive 01 F250. It’s just hit 99k so I’ve done an oil change and flushed the trans and radiator and now I’m going to replace the tie rods and ball joints. What is the current flavor for brand of steering components and ball joints for a RWD?
Old Apr 5, 2021 | 08:45 PM
Walleye Hunter's Avatar
Walleye Hunter
I think XRF is still a good option. I got mine off of MIBearings last time around and I'd use them again.
Old Apr 6, 2021 | 01:42 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Bad luck with Raybestos tie rods on my 4X4, danger Will Robinson.
Ball joints I'd go Dana Spicer 2020314 kit. Complete with yellow o rings. But there are options, wait for more input.
Old Apr 6, 2021 | 06:43 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Spicer and XRF are the current top choices in my mind. FTE'r udsuth78 has a thread about "kryptonite" parts.
https://www.ford-trucks.com/forums/1...ll-joints.html
Old Apr 6, 2021 | 06:49 AM
ESwift's Avatar
ESwift
CNCFAB
I only use the spicer kits, with the spicer sealed u joints for front axle. I use moog for the other steering components. My trucks get beat plowing and running overloaded on gravel roads daily. No issues, everything holds up well. Will never run any other type of ball joints, nothing has lasted nearly as long as oem spicer sealed units.
They are also super cost effective
Old Apr 7, 2021 | 05:10 PM
BleedMichigan
does spicer make ball joints for a RWD it was my understanding they only did the 4WD with the Dana axle
Old Apr 7, 2021 | 05:14 PM
ESwift's Avatar
ESwift
CNCFAB
That I am not sure. I totally missed the rwd part. I only have 4x4 trucks
Fandini
Aug 16, 2015 08:11 PM
eatont9999
63
Sep 30, 2012 08:55 PM
sedly
Feb 28, 2008 02:13 PM
jeeptroll
May 8, 2007 09:20 PM
rdcouch
Sep 15, 2000 10:35 PM
