Timing mark location
Old Apr 5, 2021 | 06:33 AM
Dustin Armentrout's Avatar
Dustin Armentrout
So i just replaced my IP and tried starting my 1988 f350 7.3 idi. I could instantly tell the timing is off just a hair. I was pretty sure i had the gears lined up. If so then i just need to advance/retard the pump a bit. I thought i had seen a small circle indention (on the tooth ring just below the teeth) on the second to top gear. The one below the IP gear. I got to thinking about it and remember only ever seeing diagrams with the timing marks on the front. Not really trying to take the front of my motor apart as i need to go get a parts truck that was still running when parked for 800.00. If i have too take it apart then i have too take it apart. Just wondering if they ended up stamping both sides of the gears with timing marks or just the one side? Thank you in advance.
Old Apr 5, 2021 | 09:39 AM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
just the front side.
cowmilker08
Mar 31, 2010 01:10 PM
meck1
Apr 24, 2005 12:24 PM
woodyropes
Jun 6, 2002 09:14 PM
kjsharrer
3.8 & 4.2L V6
Aug 12, 2001 09:38 AM
farmpaw
Jul 2, 2001 10:23 AM
