Phenolic teeth on timing gears
Old Jun 21, 2001 | 07:21 PM
farmpaw's Avatar
farmpaw
Old Jun 29, 2001 | 10:59 AM
brents's Avatar
brents
Hi,
This week I removed the timing gears on my 79 351M. I was suprised to see that the large gear body was metal, but the teeth were a funny phenolic or nylon material.
Anyone seen this before? Why would ford do that? Did it save them money?
BTW, my chain had 0.8" of slack, will the motor run any different/better/worse with the new chain set? Any other adjustments I should make (like timing the dist.?) with the new chain set?
Just curious,
-Brents
Old Jun 29, 2001 | 04:53 PM
dwwscran's Avatar
dwwscran
ford did this on many engines. they used nylon teeth to cut down on engine noise. all aftermarket replacements use a solid metal gear.
Old Jun 29, 2001 | 05:10 PM
whomrig's Avatar
whomrig
Brent, you will also need to check/adjust the ign. timing to complete the job. Timing will most likely change.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 2, 2001 | 10:23 AM
martinb's Avatar
martinb
Just a suggestion, but, you may want to bite the bullet and get an aftermarket roller timing set that will allow you to advance the cam ( 3 keyways on the crank sprocket ). These seem to run around $40.00. A friend of mine with a 351c Mustang says that the pre '73 timing sets are not retarded, so one of these may have the same effect.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
