79 F-250
Horn doesnt work thought it was the pad as it works if you short across to steering wheel.
Have tried 2 other pads with no results?
Anyone got any ideas?
check to make sure the continuity strap is not rotted away on the steering shaft rag joint in the engine compartment -- this strap across the 2 nuts on opposite sides of the rag joint provides a ground for the steering column --- you can replace it with some copper wire with eye lugs on each end.
it doesn't matter how it's hooked up, it's only a switch.
I assume since you say you can hook it up either way, you don't have speed control (and no horn relay)...
what is the resistance between the 2 horn pad wires when you press the horn button?
correct, measure the resistance between the 2 wires on the horn pad while pressing the area on the horn pad that normally activates the horn. Each time you press, the resistance should drop to near zero ohms.
