Horn problem
Old Dec 26, 2003 | 08:10 PM
57_ford's Avatar
57_ford
Horn problem
Hi all, I tryed to fix my horn on my 77 f150. I traced the problem all the way the steering collum shaft is not making ground. I can take a jumper wire from the steering shaft to ground and it works. But sense it turns how would you ground something like this? Thanks for any help.
Old Dec 26, 2003 | 09:11 PM
ChargerHemi's Avatar
ChargerHemi
My horn comes and goes. I think it might be the front of the steering wheel just not making contact properly.
Old Dec 27, 2003 | 08:12 AM
76supercab2's Avatar
76supercab2
If it's a 2wd there should be a wire that connects across the fiber ring in the rag joint. The rag joint is located under the hood between the steering column and the steering box. That's all there is to it.
Old Dec 28, 2003 | 09:15 AM
57_ford's Avatar
57_ford
Thanks for the help. That is all it was. A borgeson steering shaft was put on this truck before I bought it. I now know what I need to do. I am going to make jumper wires to jump the U joints.
Old Dec 28, 2003 | 11:56 AM
joepickettf-250's Avatar
joepickettf-250
JC whitney air horn that should fix it
