What torque converter?
Old Apr 2, 2021 | 12:32 PM
Flecker's Avatar
Flecker
I have a 1974 F100 4x4, 360FE and a C6/ NP205 transfer case... the parts store has a couple of different options.
This truck is going to be a simple daily driver with some mild wheeling, nothing crazy. The difference is the pilot length and I'm not sure which one is for my application. Any idea?
This one~ Pro-King Torque Converter FM127 | O'Reilly Auto Parts
Torque ConverterTransmission Code: C6; Non-Lock-Up; 12.750 Inch Overall Diameter; 11.440 Inch Bolt Pattern; 4 Stud; 3/8-24 Thread; Milled Flat Hub; 1.375 Inch Pilot Diameter; 1.610 Inch Pilot Length; 31 Spline; 1800-2200 Stall
Or this one~ Pro-King Torque Converter FM128 | O'Reilly Auto Parts
Torque ConverterTransmission Code: C6; Non-Lock-Up; 12.750 Inch Overall Diameter; 11.440 Inch Bolt Pattern; 4 Stud; 3/8-24 Thread; Milled Flat Hub; 1.375 Inch Pilot Diameter; 1.550 Inch Pilot Length; 31 Spline; 1750-2000 Stall
Old Apr 2, 2021 | 02:00 PM
Flecker's Avatar
Flecker
Anyone? Need to get this ordered asap...
Appreciate any help.
redroad's Avatar
redroad
If you have the divorced transfer case then the C-6 is a 4wd only C-6 and is the shorter of the two in order to accommodate the divorced transfer case. If you don't no look under your truck and if there us a short piece if drive shaft running from the back of the C-6 transmission to the front of the transfer case. This indicates you have a divorced transfer case and therefore have the short C-6 tranny.
Old Apr 2, 2021 | 02:04 PM
Flecker's Avatar
Flecker
Mine is married... so the longer one is it?
Old Apr 2, 2021 | 02:06 PM
ford390gashog's Avatar
ford390gashog
This has no impact on the TC.
Old Apr 2, 2021 | 02:07 PM
redroad's Avatar
redroad
I only get one choice for the C-6
Old Apr 2, 2021 | 02:13 PM
ford390gashog
Neither of those are for a FE. The FE uses a 1.848 pilot.
Old Apr 2, 2021 | 02:14 PM
Flecker's Avatar
Flecker
Now I am more confused.
Flecker's Avatar
Flecker
ok...
I will have to re-evaluate then...
Old Apr 2, 2021 | 02:32 PM
Flecker's Avatar
Flecker
Can anyone point me in the right direction on WHERE to measure my old torque converter with a mic so I can order the correct one? Thanks!
Even better, if anyone with the same set up has replaced theirs and knows exactly what I need... PLEASE halp!
Old Apr 2, 2021 | 02:43 PM
moose4x4's Avatar
moose4x4
FTE Emeritus
Maybe you need this.
https://tricomponent.com/part/Torque.../Pilot/FX-17-6
Old Apr 2, 2021 | 03:07 PM
Flecker's Avatar
Flecker
OK... after some research on another site I found an answer... I think. The rear of the crank has TWO indentions ground into it. The 1.878 Pilot is a shorter snout. The 1.375 Pilot is a longer snout... apparently EITHER will work.
I just went and looked at the back of my crank, and this seems to be the case, Nice of Ford to do that.
Old Apr 2, 2021 | 03:11 PM
Flecker's Avatar
Flecker
Heres a picture for reference...
Crank... larger 1.878 and step down to 1.375
Old Apr 2, 2021 | 04:32 PM
Flecker's Avatar
Flecker
So if anybody can verify this it sure would be appreciated... I don't need a race application, those things are STUPID prices. Just a plain jane torque converter. Surely someone has a link or info that can help? Has anybody here actually changed one out?
Old Apr 2, 2021 | 04:42 PM
redroad's Avatar
redroad
Did you even check the link I posted above. Here's the specs.
