Backlash/Gear Pattern
Old Apr 1, 2021 | 08:28 PM
Dave408's Avatar
Dave408
1st time regear,
Backlash spec for my F350 is 11 to 16. The backlash on all ring gear teeth is .011 to .013 except for 4 teeth in a row are .010 (PIC), Opinions? I've also included a pic of the gear pattern, opinions? Thanks
Old Apr 2, 2021 | 12:00 PM
WWR's Avatar
WWR
I'd push the pinion in, you're high on the ring
Old Apr 2, 2021 | 12:13 PM
ford390gashog's Avatar
ford390gashog
The carrier also needs to be shimmed over, looks to be riding high on the teeth.
Old Apr 2, 2021 | 12:25 PM
Dave408's Avatar
Dave408
I'm concerned if I shim the Carrier over I will loose to much backlash, I'm already at .010in four places.
Old Apr 2, 2021 | 01:09 PM
WWR's Avatar
WWR
Yep, you're on the right track. Set backlash, then run pattern. Adjust pinion only. If pattern is good and backlash is in spec you're set. If for some reason backlash falls out of spec you'll have to shim carrier, but you can wind up chasing your tail (so hopefully you find a happy medium)
Typically moving just the pinion a little won't change backlash MUCH but as usual ALL DISCLAIMERS, YMMV etc apply
But I'm personally not thrilled with that pattern so I'd bump the pinion toward the carrier c/l a bit and see if you can get your contact patch closer to the roots
Old Apr 2, 2021 | 01:21 PM
Dave408's Avatar
Dave408
Thanks 4 the input WWR, I don't want to put you on the spot...but how much more shim would you slip under the pinion head. I realize its hit or miss. Thanks
Old Apr 2, 2021 | 01:46 PM
Lime1GT's Avatar
Lime1GT
Maybe this will help if you don't already have it. https://performanceparts.ford.com/do...htM-4209-8.pdf
It does list some shim variances for correction of backlash.
Old Apr 2, 2021 | 01:58 PM
Dave408's Avatar
Dave408
Thanks 4 your time and input WWR. I may not get to it today and its going to be tough working under my truck with my Easter bonnet on. Happy Easter to ya!
Dave408
Apr 2, 2021 08:57 AM
Dave408
2004 - 2008 F150
Mar 29, 2021 05:31 PM
nsboyd1210
Oct 19, 2020 09:19 AM
cbrown9064
Apr 1, 2020 10:48 PM
wizzard351
Feb 26, 2008 11:50 PM
