I'm converting my 85 f100 from a 2WD 4.1l, c4, 8.8
to a 460, C6+Np205, Dana 60, which is all out of a 78 bronco i was wanting to use the removable cover which the 4WD shifter goes through in the floor instead of just cutting an elongated hole in my floor.
My question is does anyone know if the cover from the bronco will fit the outline in my floor if i cut it out? I've tried measuring it a couple of times and haven't been able to get very acurate measurements however it does look fairly close even with my inacurate measurements.
