high hump or low hump??
Old Apr 29, 2003 | 12:08 PM
Astrojet707's Avatar
Astrojet707
I have a '72 F100 2WD with a 360 and column shift. It has a C6 transmission. Now it is time to replace the floor mat with a new one. My question is..is it a low or high hump? The floor pan tunnel has a raised type metal cover screwed on to it which is about 2 inches high or so. I assume that must be some kind of access cover to get to the transmission. I measured the height from the floor pan to the tunnel top, about 5" and then that cover thing brings it up to almost 8" high. All these shops keep saying that any column shift automatic takes a low hump floor mat. But I remember seeing somewhere that the C6 needs the high mat. Anyone have any ideas? I don't want to order one until I know exactly which one I need.
Old Apr 29, 2003 | 08:31 PM
mk's Avatar
mk
They generally used the high tunnel to clear the four speed trans and in the four wheel drives. You obviously have the high tunnel if there's a cover screwed to the floor pan, so that means ordering the taller carpet.
mike
Old Apr 29, 2003 | 10:35 PM
8NRay's Avatar
8NRay
You need the HIGH hump style carpet.
Old Apr 29, 2003 | 11:14 PM
Astrojet707
Smile high hump or low hump??
Thanks guys. None of the clerks on the phone from any of the parts houses seemed to know the answer. FTE to the rescue again!
Thanks,
Mike
john jamieson
18
Jul 6, 2017 11:36 PM
ceetwarrior
May 3, 2017 05:37 PM
Bulldog187th
Sep 23, 2016 01:01 AM
notthemaniusedtobe
Apr 7, 2015 09:04 PM
rwrogers
19
Aug 27, 2014 12:36 PM
