7-pin connector question
Old Mar 29, 2021 | 08:30 PM
Oltmans100's Avatar
Oltmans100
When in the 12V aux hot on the 7-pin connector? I treid with arunning engine, keyfob in the car and doors closed (as I read in forum), but still no 12v aux on the pin. I think first it need to reconnize that the trailer by hooking up the trailer but then I cannot test the power (if connected). Please I need some advise.
Thanks, I have a 2021 F250 Super Duty 6,7 Power Stroke.
Old Mar 29, 2021 | 08:50 PM
RV_Tech's Avatar
RV_Tech
Connect your trailer and use a multimeter on the trailer battery. If you see over 12.8 VDC, the charge lead is powered.
Steve
Old Mar 29, 2021 | 09:07 PM
Oltmans100's Avatar
Oltmans100
Steve, thanks I will check this tomorrow. Can you also inform me how to check the left blinker/brake signal on the 7-pin connector? Because when I hook up my trailer and use my left blinker in TV it will give an error message to check my left lamps. But when I connect my "old" TV (Nissan Armada) my left blinker is working on the trailer!
Thanks.
Old Mar 29, 2021 | 09:13 PM
RV_Tech's Avatar
RV_Tech
Start by just going the obvious and clean the all the pin on the seven pin on the TV ;that is giving you the fault message.
Steve
Old Mar 30, 2021 | 02:07 PM
Reel Kahuna's Avatar
Reel Kahuna
Check left trailer fuse on your TV that's not working.
Old Mar 31, 2021 | 05:18 AM
Trawlerphil's Avatar
Trawlerphil
I just went through a nightmare with my trailer lights. I added a Hopkins in-bed connector and couldn't get anything to work. I even dove into the 25,000 page service manual, bought a plug in 7 pin diagnostic device, hand checked all 8 fuses that had the word "trailer" in them and finally found it was a bad ground. A normal alternator puts out 13.8 to 14.2 volts. What is the voltage on your trailer battery?
Old Mar 31, 2021 | 10:39 AM
RV_Tech's Avatar
RV_Tech
Grounding problems account for 80-90% of all seven pin problems. As to the voltage, it depends on the connections, the condition of the connection, etc. Some voltage drop is normal. You will want to see more than 13 VDC to maintain the batteries while on the road. Do not expect to see a very large amperage output from the charge lead.
Steve
Old Apr 1, 2021 | 07:26 AM
SpencerPJ's Avatar
SpencerPJ
I agree, grounds are frequent culprits. I have some clip leads and a spool of wire, I will make great make shift temporary grounds to do testing.
Old Apr 1, 2021 | 07:27 AM
RV_Tech's Avatar
RV_Tech
Jumper cables can often fill the bill too.
Steve
kirkules
1997 - 2003 F150
Jul 13, 2020 05:16 PM
Scorpion2
Apr 19, 2019 08:00 PM
1956Fatfenders
Aug 6, 2017 12:47 PM
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
VTRACER
2004 - 2008 F150
Aug 18, 2008 10:23 PM
