2020 transmission question
Old Mar 29, 2021 | 07:53 PM
franklinsford's Avatar
franklinsford
3rd Gear
I drive a 2020 F150 XLT at work. Over the weekend I was on a trip and noticed that when I take off from a stop it skips 2nd gear and goes straight to 3rd. Seems as there is just a very little hesitation between 1 to 3. All other gears seem fine. Has the 10 speed transmission. Coming to a stop it skip also. Goes from 10 down skips 2 goes to 1. This is all according to the display on dash. Problem or normal??? I'm thinking problem. Truck has 28000 miles on it.
Old Mar 29, 2021 | 08:31 PM
Robbgt's Avatar
Robbgt
Completely normal. The 10R80 is designed to skip gears. Usually under light/moderate a acceleration it will do 1-3-5 then the rest.
No problem and nothing to worry about.
Old Mar 29, 2021 | 09:02 PM
franklinsford
3rd Gear
Thanks for the reply. Most driving is under light to moderate conditions so that's what it is. Seemed to smooth most of the time. I like the EcoBoost engine in it. Has power if you ask and if not gets decent mileage.
Old Mar 30, 2021 | 06:44 AM
SpencerPJ's Avatar
SpencerPJ
X2, normal. If you want it to hold out and hit all the gears, select Sport mode. I turned my gear indicator off many miles ago.
Jonesy0027
2015 - 2020 F150
Oct 22, 2019 08:03 AM
xzsbkn
2015 - 2020 F150
Mar 13, 2019 11:36 AM
Ford-N-floored
2015 - 2020 F150
Nov 27, 2015 09:37 PM
brightideaselectric
6.7L Power Stroke Diesel
13
Feb 11, 2012 08:27 PM
Pickup Man
Oct 5, 2002 09:42 PM
